For some time, it is impossible for me to save MKV to a NFS share. It worked well before. I tested the backup of an audio CD to the NFS share with Sound Juicer and it works well. So, i don't think that is my share.
Tested with MakeMKV 1.8.3 and 1.8.4.
On ArchLinux, Kernel 3.9.9 64bits.
Someone would have a possible solution for that?
Thanks.
Unable to save to NFS share
austingrd
Re: Unable to save to NFS share
This one is a tough one. Is there any error message when you're trying to do this? Additionally, was there something modified on your box prior to getting this issue?
Mistakes are learning tools.
