dtsdecoderdll.dll
Cheddar
dtsdecoderdll.dll
Post by Cheddar »
I got the file from ArcSoft TMT 6, but MakeMKV is saying the file is either too old, too new or being tampered with.
Re: dtsdecoderdll.dll
A search for "dtsdecoderdll" on this forum comes up with several matches, including a thread on this exact version. In that thread, it was pointed out that the ArcSoft DLL is a 32-bit DLL, which will cause a problem if you're using the 64-bit version of MakeMKV... which is the default, if you're running under a 64-bit version of Windows.
I have no idea if that is true, though.
Post by mike admin »
Cheddar wrote:I got the file from ArcSoft TMT 6, but MakeMKV is saying the file is either too old, too new or being tampered with.
Fixed in 1.8.4
austingrd
Post by austingrd »
Bug fixes:
Rarely, some episodes could be missing on a series blu-rays
When using audio transcoding, channel layout was incorrect for certain DTS-HD surround modes
Default/forced flag profile settings were ignored after 1.8.2 change
FYI for the bug change at version 1.8.4
Mistakes are learning tools. Image
