Saving only 1st title from Bluray Disc do I need full ver.
LTGoldman
#1 Post by LTGoldman » Sun Jul 14, 2013 9:40 am
Hello, I have downloaded version 1.8.3 of MakeMKV for backing up my purchased Bluray box set of Band of Brothers and it seems to be able to rip the first title from each disc but not the second. I see that there is a button for Saving Selected Title but it is all greyed out. Do I need to buy the full version to get this functionality?
Any comments given would be appreciated.
Many thanks,
LTGoldman
Smithcraft
Re: Saving only 1st title from Bluray Disc do I need full ve
#2 Post by Smithcraft » Sun Jul 14, 2013 9:07 pm
Should work, but maybe there is a different issue.
SC
#3 Post by Woodstock » Mon Jul 15, 2013 12:12 am
Follow the instructions linked to in my signature.
The difference between the "trial" version and a "purchased" version is in the activation key; the trial key expires after a certain period of time, and you have to come back here to get the new key for the month, or the latest version if one has been released. Once you buy, the key you get doesn't expire.
But, there are a lot of issues that can come up with Bluray and episodic programs like TV shows. Without logging turned on, though, it's hard to say what you're encountering.
