I'm hoping somebody can help because I'm going nuts.
I acquired dtsdecoderdll.dll from a newly installed Arcsoft TMT.
When I try to decode DTS-HD to FLAC MakeMkV tells me the .dll is too old or being tampered with, then crashes.
Any ideas? Only thing I can think of is a .dll mismatch between MakeMKV (x64) and Arcsoft TMT (x32)
Thanks in advance!
MakeMKV crashes when trying to decode DTS-HD to FLAC
madfloyd
austingrd
Re: MakeMKV crashes when trying to decode DTS-HD to FLAC
I think everything points to the bit version. Have you tried asking Arcsoft if they have a dll for 64 bit? Just to test it out.
Mistakes are learning tools.
madfloyd
Arcsoft doesn't seem to have a x64 bit version.
Can someone point me to a 64x version of the .dll?
