Hiya,
On a couple of DVDs, I get 'CellWallk algorithm failed, trying CellTrim', and then the program exits.
So far, it's happened on:
Men In Black (PAL R2)
Memento (NTSC R1)
Memoirs of a Geisha (NTSC R1)
Saw IV (NTSC R1)
Is there a fix for this error?
CellWallk Error
- Contact:
Re: CellWallk Error
likely, but we would need to look at IFO files. please pack them with archiver of your choice and send to support@makemkv.com
Re: CellWallk Error
Will do when I get home.
It's interesting to note that even after ripping them to HD with AnyDVD and using these files (as IFO or ISO) I get the same error!
Re: CellWallk Error
hay how did you repair the cellwalk problem???
Re: CellWallk Error
i am having same problem as you thanks a million guy!
