Periods changed to underscores in filenames
VinceV
Post by VinceV » Fri Jun 21, 2013 12:01 pm
Even when manually overriding the filename of a title, MakeMKV will replace periods with underscores. Is this by design? It would be nice if it used the filename as specified by the user.
Thanks,
Vince
Re: Periods changed to underscores in filenames
Post by mike admin » Sat Jun 22, 2013 5:59 am
VinceV wrote:Even when manually overriding the filename of a title, MakeMKV will replace periods with underscores. Is this by design? It would be nice if it used the filename as specified by the user.
No, you're overriding the "title name" and MakeMKV assigns default filename with underscores. You can override the file name as well, just select "File Name" in combo box.
VinceV
Post by VinceV » Sat Jun 29, 2013 10:29 pm
Hi Mike,
Can you please double-check this? I am 100% sure I'm overriding the filename.
-Vince
Tinface
Post by Tinface » Wed Jul 10, 2013 8:09 am
I am having the same issue with MakeMKV 1.8.3 on Windows 8 64 bit.
I set the name 'Rome.s02e02.Son of Hades'. The file name is automatically set to 'Rome_s02e02_Son_of_Hades'. I then set the file name to 'Rome.s02e02.Son of Hades', the exact same as the name. The file name actually used is 'Rome_s02e02_Son of Hades'. This is reflected both by the file generated and the output file listed in the GUI during ripping.
An option to mirror filename from name would be sweet too.
Thank you for an otherwise great product. MakeMKV rocks.
Edit: Added MakeMKV version number.
Smithcraft
Post by Smithcraft » Wed Jul 10, 2013 10:10 am
I suggested such a thing, as mirroring them or having filename as the default to change rather than metaname, but was shot down in flames. :roll:
SC
Post by mike admin » Fri Jul 12, 2013 9:08 am
The "dot removal" bug is confirmed, will be fixed in 1.8.4. Should be available in a few days.
Tinface
Post by Tinface » Fri Jul 12, 2013 12:54 pm
mike admin wrote:The "dot removal" bug is confirmed, will be fixed in 1.8.4. Should be available in a few days.
Nice one, thanks a lot.
VinceV
Post by VinceV » Sat Jul 13, 2013 1:42 am
Awesome; thanks Mike!
