While copying Looper
JenniferEJ
#1 Post by JenniferEJ » Fri Jul 05, 2013 11:35 pm
I had this error message while copying Looper Blu-ray:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00009.m2ts' at offset '236845056'
What can that be.
Thanks.
Lovely Rita
Re: While copying Looper
#2 Post by Lovely Rita » Sat Jul 06, 2013 12:41 pm
Try cleaning it first but more than likely replacing the disc is the solution. I recently had to exchange 3 copies of Monster's Inc before I finally had one that would rip correctly. All of them would play fine in our Oppo blu ray player.
Registered User :wink:
Buy MakeMKV
#3 Post by Woodstock » Sat Jul 06, 2013 12:43 pm
Your drive couldn't read part of the disk. Try cleaning it.
MakeMKV (and any ripper, for that matter) want a 100% exact copy of the data on the disk. Your typical player, though, will accept unreadable data and skip over it, so a disk might "play" just fine, but be damaged.
JenniferEJ
#4 Post by JenniferEJ » Sat Jul 06, 2013 2:50 pm
Thanks a lot! I cleaned my disc and everything works just fine.
Thanks again!
