Problem ripping Spartacus BaS Episode 1
Batiatus
Post by Batiatus »
I've tried multiple times, on 2 different machines, to rip Spartacus Blood and Sand season 1 episode 1 and it's failed every single time. It gets to about 56 seconds remaining and then the time starts to climb and climb and climb until I just get a fail message. It's the only episode of the series I can't rip and it's driving me mad! Any help?
Re: Problem ripping Spartacus BaS Episode 1
Logs would help matters. How to get logs is in my signature.
setarip_old
Post by setarip_old »
Hi!
Have you tried cleaning the disc?
Batiatus
Post by Batiatus »
setarip_old wrote:Hi!
Yes, tried that a couple times. Same error keeps happening.
Tried it again, got to 16 seconds remaining and then it crashed. Tried to log the error but not sure it worked. Bloody frustrating!
If logging is turned on, you'll see something like this in the log box:
MakeMKV v1.8.3 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\XXXXXXX/MakeMKV_log.txt
Rick.Glos
Post by Rick.Glos »
I'm having a similar problem. I've tried ripping from 2 separate discs so far with the same failure to record the episode.
Attached is my log file.
MakeMKV_log.txt
(10.06 KiB) Downloaded 591 times
