I'd like to see a way to lock makemkv to one drive.
That is to run makemkv /dev/sr2 from the command line and have it only work on that drive.   I tend to run multiple copies of makemkv at the same time and it's auto-sensing get's annoying especially if one of my drives is running slow.  It can take several minutes when you insert a disk.
						Way to lock makemkv to one drive and specify on command line
				MikeyCarter
Re: Way to lock makemkv to one drive and specify on command
Hi Mike, have you found a way to do this already? I'm not really sure but I don't think that this is possible yet. Perhaps in the future, developers could develop this.
									Mistakes are learning tools.
Did you try the command line paramter "dev:/dev/sr2"?  That's works for me here in stream mode:
$ ps aux | grep \[m]ake
$USER       46457  5.2 13.3 948108 540260 ?       Ssl  16:09   0:32 makemkvcon --bindport=52034 stream dev:/dev/sr0-
- Contact:
Thant's how it works right now (for command line). If you specify the drive name then MakeMKV will only use this particular drive. To skip scanning all drives specify --noscan.MikeyCarter wrote:I'd like to see a way to lock makemkv to one drive.
