Beverly Hills Cop Blu-Ray
trevoriginal
#1 Post by trevoriginal » Wed Jun 26, 2013 3:52 am
I've tried about 5 times. Even sent the disc back to thinking it was damaged, but I'm getting errors with the replacement disc as well. Rebooted. Powered off/on external BR drive. Powered down BR drive, pulled power and firewire, and then plugged back in. All with the same result.
I've been using MakeMKV for nearly 3 years. I've never seen this error before on any DVD/BR.
Error in attachment.
First time on forum. Go easy on me.
Screen shot 2013-06-25 at 11.43.10 PM.png (40.53 KiB) Viewed 11140 times
trevoriginal
Re: Beverly Hills Cop Blu-Ray
#2 Post by trevoriginal » Wed Jun 26, 2013 8:58 pm
I just tested a few other BRs and they worked fine. Doesn't seem to be a hardware issue.
crowfax
#3 Post by crowfax » Thu Jun 27, 2013 4:25 am
Your drive is telling you it can't read the disc. There are only 2 options:
1. Bad disc.
2. Bad drive.
Its no surprise that you have a replacement which also has the same issue, poorly pressed discs come in batches. Just return it again and ask for another.
trevoriginal
#4 Post by trevoriginal » Thu Jun 27, 2013 12:44 pm
I'll go the replacement route in hopes that I get a disc that works. Thanks for the help.
