I've tried about 5 times. Even sent the disc back to thinking it was damaged, but I'm getting errors with the replacement disc as well. Rebooted. Powered off/on external BR drive. Powered down BR drive, pulled power and firewire, and then plugged back in. All with the same result.
I've been using MakeMKV for nearly 3 years. I've never seen this error before on any DVD/BR.
Error in attachment.
First time on forum. Go easy on me.
Beverly Hills Cop Blu-Ray
trevoriginal
- Screen shot 2013-06-25 at 11.43.10 PM.png (40.53 KiB) Viewed 11133 times
trevoriginal
Re: Beverly Hills Cop Blu-Ray
I just tested a few other BRs and they worked fine. Doesn't seem to be a hardware issue.
crowfax
Your drive is telling you it can't read the disc. There are only 2 options:
1. Bad disc.
2. Bad drive.
Its no surprise that you have a replacement which also has the same issue, poorly pressed discs come in batches. Just return it again and ask for another.
1. Bad disc.
2. Bad drive.
trevoriginal
I'll go the replacement route in hopes that I get a disc that works. Thanks for the help.
