Errors running MakeMKV on OS X 10.9 DP
nwoolls
Post by nwoolls »
First I want to say I am not looking for a fix or support as I'm sure running your software on a beta OS is not supported. I just wanted to bring it to your attention in hopes that it is something you can fix for the release of the OS this Fall.
The most common error seems to be a dialog that pops up saying 'Fatal error occurred, the program will now exit'. I've seen this opening a disc, in the middle of ripping, or with the app just sitting there doing nothing at all. I've also occasionally received a full error with call stack.
I've captured some images, as well as the debug output and callstack here. Thanks for the great application!
Kewler
Re: Errors running MakeMKV on OS X 10.9 DP
Post by Kewler »
I'm also using MakeMKV 1.8.3 on OS X 10.9 DP1 and, for me, it's the DASPI kernel extension that doesn't load.
Post by mike admin »
Kewler wrote:I'm also using MakeMKV 1.8.3 on OS X 10.9 DP1 and, for me, it's the DASPI kernel extension that doesn't load.
Other than DASPI, does MakeMKV crash? Also, doest it tell you to install DASPI (DASPI is optional for majority of drives since 1.8.1, you don't have to install it unless MakeMKV tells you to do so).
Kewler
Post by Kewler »
mike admin wrote:Other than DASPI, does MakeMKV crash? Also, doest it tell you to install DASPI (DASPI is optional for majority of drives since 1.8.1, you don't have to install it unless MakeMKV tells you to do so).
MakeMKV doesn't crash: I ripped a BD under 10.9 DP1 without a hitch. I'm using a LaCie USB3 external BD-drive (Optiarc inside).
Even though DASPI is optional, I was under the impression that it provided better or more direct "communication" between MakeMKV and the optical drive, no?
Kewler wrote:Even though DASPI is optional, I was under the impression that it provided better or more direct "communication" between MakeMKV and the optical drive, no?
Yes before version 1.8.1 . After 1.8.1 you don't need DASPI unless MakeMKV explicitly tells you to install it.
sparkplug
Post by sparkplug »
I would disagree. MakeMKV was working without any problem till I used it under 10.9B1 then I could not rip several films and I did try. It would start to rip but it would fail part way though and before that it would have long pauses. In the end I connected an old USB drive to my mac air which is still running 10.8 and it ripped perfectly without any hold ups.
That said I've just updated to 10.5B2 and are currently ripping and disc and its almost half way so fingers crossed. I had also noticed that my Transmission (Torrent client) had a huge memory leak so I personally think 10.5B1 has issues and not the software running on top of the OS.
Dave
sparkplug
Post by sparkplug »
Just ripped a DVD and Blu Ray without any noticeable problem using the 10.9 beta 2. So it looks good except for the fact I could not load DASPI even if I wanted too.
thelegume
Post by thelegume »
Thanks for the update on how it's working in 10.9b. I ran 10.9 DP1 for a bit but some of my crucial software was bugging out, so I rolled back to 10.8.4 to wait. It seems like MakeMKV is working normally in 10.9 DP2--now, after several days, is that what you are still seeing? I might go back up to 10.9 before release if MakeMKV and some other software is already stable.
sparkplug
Post by sparkplug »
thelegume wrote:Thanks for the update on how it's working in 10.9b. I ran 10.9 DP1 for a bit but some of my crucial software was bugging out, so I rolled back to 10.8.4 to wait. It seems like MakeMKV is working normally in 10.9 DP2--now, after several days, is that what you are still seeing? I might go back up to 10.9 before release if MakeMKV and some other software is already stable.
I'm now running 10.9 DP3 and its still all OK and I've ripped around 10 Blu ray and 5 DVDs in that time. Last time I ran Transmission it still had big memory leaks so the OS still has some big holes in it.
captain
Post by captain »
I have been having that error repeatably since MakeMKV 1.8.3, and I'm only on Mt. Lion 10.8.3. MakeMKV 1.8.4 does not resolve the "Fatal error occurred, program will now exit." error. I do have DASP 1.3 installed, and no idea how to completely remove it.
I believe the only way to get MakeMKV to run is to reboot, and then it'll be a 50/50 proposition. At least it still runs when it doesn't crash. :-P
liner
Post by liner »
I have had terrible luck with 1.8.4 and Mavericks DP Build 13A524d ( the latest version) . I almost always (49 out 50) get fatal program errors. Sometimes a gig or two into the rip sometimes longer sometimes while it is sitting idle. Right now for instance I launched it to get the version of MakeMKV and it just crashed. I don't even have a BD in the drive... Here's to hoping this gets fixed soon.
P.S. Love the program and I will be a paid customer when that time comes...
crowfax
Post by crowfax »
liner wrote:P.S. Love the program and I will be a paid customer when that time comes...
The time is already here if you don't want to keep updating the beta key and messing around:
www.makemkv.com/buy
thelegume
Post by thelegume »
It looks like the 'Fatal error occurred, the program will now exit' error is back. Everything was working fine until today and I have now gotten it 6 out of 6 times. Sometimes it will happen as the program is sitting idle, sometimes in the middle of a rip or decrypt. I'm looking for a crash log or something in console but not finding it yet--I'll post it if I do.
I'm on OSX 10.9 beta 4 (latest) running MakeMKV 1.8.4
Edit: Here is a crash log I got one of the times it quit:
Process: makemkv [6203]
Path: /Applications/MakeMKV.app/Contents/MacOS/makemkv
Identifier: com.makemkv.MakeMKV
Version: v1.8.4 (0)
Code Type: X86 (Native)
Parent Process: launchd [256]
Responsible: makemkv [6203]
User ID: 501
Date/Time: 2013-07-30 07:30:41.143 -0600
OS Version: Mac OS X 10.9 (13A524d)
Report Version: 11
Anonymous UUID: 38662D62-ED36-4809-44BB-5CA916459666
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000004
VM Regions Near 0x4:
--> __PAGEZERO 0000000000000000-0000000000001000 [ 4K] ---/--- SM=NUL /Applications/MakeMKV.app/Contents/MacOS/makemkv
__TEXT 0000000000001000-00000000062fe000 [ 99.0M] r-x/rwx SM=COW /Applications/MakeMKV.app/Contents/MacOS/makemkv
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libmqt.dylib 0x065a63b8 QLabel::setText(QString const&) + 12
1 com.makemkv.MakeMKV 0x0001a2d1 0x1000 + 103121
2 com.makemkv.MakeMKV 0x0001a162 0x1000 + 102754
3 com.makemkv.MakeMKV 0x0001cd8c 0x1000 + 114060
4 com.makemkv.MakeMKV 0x0001dbad 0x1000 + 117677
5 com.makemkv.MakeMKV 0x000094ec 0x1000 + 34028
6 libmqt.dylib 0x063a101a QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 1652
7 libmqt.dylib 0x063bf4b3 0x630c000 + 734387
8 libmqt.dylib 0x063a03d8 QObject::event(QEvent*) + 60
9 libmqt.dylib 0x063c3296 0x630c000 + 750230
10 libmqt.dylib 0x063c3409 0x630c000 + 750601
11 libmqt.dylib 0x063939bc 0x630c000 + 555452
12 libmqt.dylib 0x063c2d06 0x630c000 + 748806
13 libmqt.dylib 0x0668246d 0x630c000 + 3630189
14 com.apple.CoreFoundation 0x98249666 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 22
15 com.apple.CoreFoundation 0x9824902a __CFRunLoopDoTimer + 1354
16 com.apple.CoreFoundation 0x9822e5c3 __CFRunLoopRun + 2515
17 com.apple.CoreFoundation 0x9822d5da CFRunLoopRunSpecific + 394
18 com.apple.CoreFoundation 0x9822d43b CFRunLoopRunInMode + 123
19 com.apple.HIToolbox 0x9aa7a6cd RunCurrentEventLoopInMode + 259
20 com.apple.HIToolbox 0x9aa7a44c ReceiveNextEventCommon + 526
21 com.apple.HIToolbox 0x9abe03b7 _BlockUntilNextEventMatchingListInModeWithFilter + 92
22 com.apple.AppKit 0x99382209 _DPSNextEvent + 1602
23 com.apple.AppKit 0x99381730 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 119
24 com.apple.AppKit 0x9937895c -[NSApplication run] + 727
25 libmqt.dylib 0x06683fe4 0x630c000 + 3637220
26 libmqt.dylib 0x06391de3 0x630c000 + 548323
27 libmqt.dylib 0x06393e22 0x630c000 + 556578
28 com.makemkv.MakeMKV 0x000021f4 0x1000 + 4596
29 com.makemkv.MakeMKV 0x00001f76 0x1000 + 3958
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x98188966 kevent64 + 10
1 libdispatch.dylib 0x9038ec39 _dispatch_mgr_invoke + 238
2 libdispatch.dylib 0x9038eb1a _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x9818779e __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x926dcd21 _pthread_cond_wait + 728
2 libsystem_pthread.dylib 0x926dec29 pthread_cond_timedwait$UNIX2003 + 71
3 libmqt.dylib 0x063af326 QThread::msleep(unsigned long) + 170
4 com.makemkv.MakeMKV 0x000023c4 0x1000 + 5060
5 libmqt.dylib 0x063af25b 0x630c000 + 668251
6 libsystem_pthread.dylib 0x926da5ff _pthread_body + 144
7 libsystem_pthread.dylib 0x926da489 _pthread_start + 130
8 libsystem_pthread.dylib 0x926dfcf6 thread_start + 34
Thread 3:
0 libsystem_kernel.dylib 0x98182f4a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x9818213c mach_msg + 68
2 com.apple.CoreFoundation 0x98227ca9 __CFRunLoopServiceMachPort + 169
3 com.apple.CoreFoundation 0x9822e149 __CFRunLoopRun + 1369
4 com.apple.CoreFoundation 0x9822d5da CFRunLoopRunSpecific + 394
5 com.apple.CoreFoundation 0x9822d43b CFRunLoopRunInMode + 123
6 com.apple.AppKit 0x99728159 _NSEventThread + 285
7 libsystem_pthread.dylib 0x926da5ff _pthread_body + 144
8 libsystem_pthread.dylib 0x926da489 _pthread_start + 130
9 libsystem_pthread.dylib 0x926dfcf6 thread_start + 34
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x00000000 ebx: 0xbfffc5c0 ecx: 0xbfffc5a8 edx: 0xbfffc5a8
edi: 0xbffff7f8 esi: 0x0baae118 ebp: 0xbfffc588 esp: 0xbfffc570
ss: 0x00000023 efl: 0x00210282 eip: 0x065a63b8 cs: 0x0000001b
ds: 0x00000023 es: 0x00000023 fs: 0x00000000 gs: 0x0000000f
cr2: 0x00000004
Logical CPU: 0
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x1000 - 0x62fdfe7 +com.makemkv.MakeMKV (v1.8.4 - 0) /Applications/MakeMKV.app/Contents/MacOS/makemkv
0x630c000 - 0x67d1fe7 +libmqt.dylib (1) /Applications/MakeMKV.app/Contents/MacOS/libmqt.dylib
0x681e000 - 0x686fff1 libstdc++.6.dylib (60) <73E6F78B-BF68-327F-9ACE-1D052981E444> /usr/lib/libstdc++.6.dylib
0xb900000 - 0xb9b0fff ColorSyncDeprecated.dylib (426) <B179A360-357F-3A23-8DCB-8A3A588A0DA2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0xb9f3000 - 0xba00fff com.apple.Librarian (1.2 - 1) <4BC4F43F-A50E-3802-9946-6EEB92FF52D4> /System/Library/PrivateFrameworks/Librarian.framework/Librarian
0xbb0b000 - 0xbb16ff4 com.apple.CommerceCore (1.0 - 41) <F5F0A375-3793-348E-AEF9-702D93DBF33E> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x14f97000 - 0x14fbcff9 com.apple.framework.familycontrols (4.1 - 410) <6F20088F-7E0A-34D3-9CA0-B5E2F8DC365A> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x15c07000 - 0x15d97ff8 GLEngine (9.0.77) <21184DE3-0F43-340B-912F-25C7D79C3DCF> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x15dd8000 - 0x15e04ff7 GLRendererFloat (9.0.77) <9D3B4576-A78F-3D45-B932-E207196FC906> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x15e0d000 - 0x15e15fee libcldcpuengine.dylib (2.3.49) <0B7A876F-DAF9-34B8-B819-5764FD3A6C42> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x1bffd000 - 0x1bffeff3 +cl_kernels (???) <A5A80D46-FFE1-478D-B55B-DC84568788DF> cl_kernels
0x1e0fb000 - 0x1e0fcff3 +cl_kernels (???) <BA0007E1-A2D3-415D-8C57-60A3C561352A> cl_kernels
0x1e6ea000 - 0x1e705ff5 com.apple.security.csparser (3.0 - 55397) <B9038D6B-43E9-38FD-981A-428DC2DC5340> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x1e714000 - 0x1e715ff1 +cl_kernels (???) <FF903DBB-AD11-47AF-BEE2-B2FB113D44AD> cl_kernels
0x1e71c000 - 0x1e71cffd +cl_kernels (???) <8A89A06F-2914-4040-BA96-02799A0782E5> cl_kernels
0x1e721000 - 0x1e722ffd +cl_kernels (???) <0FB855D7-EF46-4AE1-9BE3-E5DCB0BB8FC6> cl_kernels
0x1e727000 - 0x1e728fff +cl_kernels (???) <189DCA65-3DB2-47EB-92BD-62C774EBD22E> cl_kernels
0x1e72c000 - 0x1e72cff6 +cl_kernels (???) <E740DC78-3C15-4429-AA2D-BB5FAD25EF03> cl_kernels
0x1e75c000 - 0x1e75dff7 +cl_kernels (???) <002D0042-FBD9-4724-BEA7-F14454C68BE3> cl_kernels
0x1e762000 - 0x1e762ff5 +cl_kernels (???) <C9EA691D-E7F4-4B6E-A90B-E6600F1AFB17> cl_kernels
0x1e769000 - 0x1e76aff5 +cl_kernels (???) <7514232E-23CC-456C-A813-344EFEBEF7FF> cl_kernels
0x1e7f3000 - 0x1e7f4ff7 +cl_kernels (???) <BC257A84-AD14-45CB-985C-50A425A9B686> cl_kernels
0x1e7f8000 - 0x1e7f8ffd +cl_kernels (???) <2CE72CC1-9C27-49C3-8EA3-32030DCD58C0> cl_kernels
0x1f000000 - 0x1f0ebff7 unorm8_bgra.dylib (2.3.49) <D8A8E0E5-040F-39FF-AB28-CE4D82A6CA56> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x1f117000 - 0x1f202ff7 unorm8_argb.dylib (2.3.49) <20E118C6-7B7A-3F68-B0F0-6586B5211FFC> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_argb.dylib
0x40000000 - 0x404a7ff7 com.apple.driver.AppleIntelHD4000GraphicsGLDriver (8.18.14 - 8.1.8) <232BD7A5-B261-3FB9-9DA9-7ED66D73DD41> /System/Library/Extensions/AppleIntelHD4000GraphicsGLDriver.bundle/Contents/MacOS/AppleIntelHD4000GraphicsGLDriver
0x48000000 - 0x488d6ff7 com.apple.GeForceGLDriver (8.18.12 - 8.1.8) <FE47A5CA-F75A-35D6-97A3-3B2371D2267D> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x8feb8000 - 0x8feea227 dyld (239) <6F750B32-BFFF-35D3-B018-DDD2A768D971> /usr/lib/dyld
0x90008000 - 0x90014ffc libbz2.1.0.dylib (29) <3CEF1E92-BA42-3F8A-8E8D-9E1F7658E5C7> /usr/lib/libbz2.1.0.dylib
0x900b0000 - 0x900bbfff libcsfde.dylib (379) <9F05959C-C33A-3100-B832-4E7E76951BE6> /usr/lib/libcsfde.dylib
0x900bc000 - 0x90108ff7 libcups.2.dylib (369.5) <24F6D75F-C77E-3F89-9C24-F9FDE637E389> /usr/lib/libcups.2.dylib
0x90109000 - 0x90114ffb libcommonCrypto.dylib (60049) <6433E22E-3A59-30C0-8AE9-1D96E0D7086A> /usr/lib/system/libcommonCrypto.dylib
0x90115000 - 0x90167fff com.apple.ViewBridge (1.0 - 33) <0716418A-FDC5-3108-9519-79619CFB642E> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x90168000 - 0x90176ff3 com.apple.opengl (9.0.77 - 9.0.77) <482B4783-DD79-3379-93E8-59A49FCD9340> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x90177000 - 0x90179ffb libRadiance.dylib (1033) <5E09255E-F47C-3122-9C81-9855AC9D203F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x9017a000 - 0x90283fff com.apple.ImageIO.framework (3.2.0 - 1031.1) <7CE7B9BC-5719-32CA-AA41-D5912723E66F> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x90284000 - 0x90293fff libGL.dylib (9.0.77) <FA9687F8-5600-32AA-BFDB-55B7B3C27D89> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x90294000 - 0x90295fff libSystem.B.dylib (1197.1.1) <602E076E-1BA9-33D0-B6A0-1B08E0A19E7C> /usr/lib/libSystem.B.dylib
0x90296000 - 0x90383fff com.apple.backup.framework (1.5 - 1.5) <7805AB3B-C7EE-348B-B278-87F41F2F0960> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x90384000 - 0x90387ff9 com.apple.TCC (1.0 - 1) <EE7EE637-9876-32E7-A175-0A2908CFF1C9> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x90388000 - 0x9038affe libCVMSPluginSupport.dylib (9.0.77) <83E71C1C-B588-311E-AA67-7080362B4D11> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x9038b000 - 0x903a3ff5 libdispatch.dylib (339.1.5.0.1) <00E8D03F-79CD-3E76-A2EA-6796BC827A96> /usr/lib/system/libdispatch.dylib
0x903a4000 - 0x903a5fff com.apple.marco (10.0 - 1000) <1A189F07-34F6-328E-ABDD-BC00D44790E3> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
0x903a6000 - 0x903aaffa libGIF.dylib (1033) <75670991-03C1-3832-8ABF-0B9153D55FF5> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x903ab000 - 0x903dcffe com.apple.GSS (4.0 - 2.0) <E6372E15-577F-3300-8C17-9C37B43416C7> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x903dd000 - 0x9040cfff com.apple.framework.SystemAdministration (1.0 - 1.0) <F2C39562-E0F6-38FD-B5F3-D41565E1330A> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x9040d000 - 0x9040dfff libodfde.dylib (20) <A72C70B8-D230-34D4-B0A1-9B0D5CB6D13B> /usr/lib/libodfde.dylib
0x9040e000 - 0x90415fff libMatch.1.dylib (19) <A540E682-7940-351E-B93B-2DF7802AD886> /usr/lib/libMatch.1.dylib
0x90416000 - 0x904f0ff6 com.apple.QuickLookUIFramework (5.0 - 615.0) <053FBB3A-6AE4-3841-AA25-2E3235EA00B3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x904f1000 - 0x9051afff com.apple.IconServices (25 - 25.10) <8440D0FB-2AEB-326F-A2D5-168BE0E74146> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x90e76000 - 0x90f39ff9 com.apple.CoreText (352.0 - 367.9) <8028FA2E-A524-3C4C-84FF-81A8AF80B2D3> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x90f3a000 - 0x90f48ff7 com.apple.Sharing (132 - 132) <D20BFFD4-51FD-36BB-ADA2-A393976D8758> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x90f49000 - 0x90f4eff6 libcompiler_rt.dylib (35) <CCE09BCA-77A2-3568-8B2A-B8A2CAC5B373> /usr/lib/system/libcompiler_rt.dylib
0x90f4f000 - 0x90f58fff com.apple.AppleSRP (5.0 - 1) <6B946F4B-7DC4-3E82-BF2C-BE0930E3CF47> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x90f59000 - 0x90f69ff5 com.apple.LangAnalysis (1.7.0 - 1.7.0) <BB6B3E95-495D-3350-B9B2-6C2A5FA2BFD1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x90f6a000 - 0x91292fff com.apple.JavaScriptCore (9537 - 9537.51.3) <8344C1E5-427C-34F7-BEBB-368999EAF7D8> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x91293000 - 0x912d0ff7 libauto.dylib (185.5) <856F4565-8959-3ECE-8721-46B2D4406E7B> /usr/lib/libauto.dylib
0x912d1000 - 0x9130fff7 com.apple.NavigationServices (3.8 - 215) <88357F05-C974-3B52-9C6B-D80A46F7F543> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x91310000 - 0x913fbff4 com.apple.DiskImagesFramework (10.9 - 369) <D72F68C1-62EA-3126-A821-FF9D3AA7E22B> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x913fc000 - 0x9157aff6 libGLProgrammability.dylib (9.0.77) <A1CFF0CD-DE6F-3DEB-A7A2-4F136D3E0761> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x9157b000 - 0x915baff7 com.apple.bom (12.0 - 192) <A8FAEC78-A81D-3A9A-8516-2B69364F125D> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x915bb000 - 0x9172afff com.apple.QTKit (7.7.3 - 2814) <235B00B5-9976-3641-90E7-A0B84974259D> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x9172b000 - 0x9172bffe com.apple.AOSMigrate (1.0 - 1) <CD00651E-94BD-33AC-B1FC-5D8EFCF91212> /System/Library/PrivateFrameworks/AOSMigrate.framework/Versions/A/AOSMigrate
0x9172c000 - 0x9181ffff libFontParser.dylib (107) <2A117617-481D-3AF3-BF8B-9529BCC4DB46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x91820000 - 0x918bdff3 com.apple.PDFKit (2.9 - 2.9) <190E14B8-B247-3340-B407-48C2BC7E45BB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x918be000 - 0x9207effd libclh.dylib (4.0.3 - 4.0.3) <1CB599D5-2F54-3088-8893-5534B8547ACE> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x9207f000 - 0x921e0ffb com.apple.CFNetwork (665 - 665) <9BE7FEBB-A426-356B-8CC9-87727C98FC43> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x921e1000 - 0x92205fff libJPEG.dylib (1033) <C965C33C-DEB7-3119-AA82-473334C70C64> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x92206000 - 0x922dfff7 com.apple.LaunchServices (572.9 - 572.9) <FC68966E-F103-3FFB-AFAF-ED96311F64BF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x922e0000 - 0x923a7ff7 com.apple.DiscRecording (8.0 - 8000.4.6) <C48FE096-02C9-36E4-A0E1-5656FD99F7D5> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x923a8000 - 0x923f7fff com.apple.opencl (2.3.52 - 2.3.52) <DC1CC7B6-F445-30A1-9252-8F617471643A> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x923f8000 - 0x92675fff com.apple.imageKit (2.5 - 760) <E2206787-F6C1-309D-AF15-DEA3AF1A9AEA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x92676000 - 0x926a2fff com.apple.DictionaryServices (1.2 - 202) <3BDE16D1-43F5-3F6A-8906-AEE9218788BD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x926a3000 - 0x926a6ffe com.apple.LoginUICore (3.0 - 3.0) <3AA2C2EB-F04C-3E1D-924D-6F0AA7C1C2F5> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x926a7000 - 0x926d8ff4 com.apple.securityinterface (9.0 - 55047) <416E54CC-8D59-35AD-A46D-4099A3269B53> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x926d9000 - 0x926e0ffb libsystem_pthread.dylib (53.1.2) <53556F6B-1176-36DB-AB53-25F954EB231A> /usr/lib/system/libsystem_pthread.dylib
0x926e1000 - 0x926e2fff liblangid.dylib (117) <F18F76C6-7E4B-34AD-AE81-C1C031BF2F7D> /usr/lib/liblangid.dylib
0x926e3000 - 0x926e9fff com.apple.MediaAccessibility (1.0 - 38) <942A2F25-1C29-3233-8978-E0740505F3F8> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
0x926ea000 - 0x926f4ff7 com.apple.speech.synthesis.framework (4.5.5 - 4.5.5) <246F43FD-CC21-3821-8C63-6E74B0BD209F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x926f8000 - 0x926f9ffd libunc.dylib (28) <B63E171F-42FE-3178-A9EF-70A4FB7AF8B5> /usr/lib/system/libunc.dylib
0x926fa000 - 0x926fbff7 com.apple.diagnosticlogcollection (10.0 - 1000) <6BA427DA-0449-3370-8F01-194144F66416> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection
0x9272d000 - 0x92736fff com.apple.audio.SoundManager (4.1 - 4.1) <0734E016-5336-3307-A5E3-8779FA98FCCE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x92786000 - 0x927a0ff1 com.apple.openscripting (1.4 - 154) <8CC3523C-AE78-3799-91F9-4CB0C03E2D9E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x927a1000 - 0x927a2fff libremovefile.dylib (33) <BB6B805A-B28F-3DCE-88D9-C854C81761CE> /usr/lib/system/libremovefile.dylib
0x927a3000 - 0x928d9ff3 com.apple.desktopservices (1.8 - 1.8) <E59BBD9F-BE4E-3E84-81F4-7137EE76FC3B> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x928da000 - 0x928e4ff3 com.apple.DisplayServicesFW (2.8 - 360.8.11) <514F63B2-DCE4-3F4F-BF77-466648DD1EF7> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x928e5000 - 0x92939fff com.apple.AppleVAFramework (5.0.26 - 5.0.26) <94CD823A-B58D-3132-867E-3C5C28CFACE4> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x9293a000 - 0x92980fff libcurl.4.dylib (78) <ED19DBB8-C70A-304B-A6ED-6F292749C6B4> /usr/lib/libcurl.4.dylib
0x92981000 - 0x929e1ff7 com.apple.Symbolication (1.4 - 127) <65ACEB6D-AC95-31E0-AB8A-0EA9CB99BE42> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x929e2000 - 0x929e2fff com.apple.Carbon (154 - 157) <C20AA35D-3483-32C7-9BDD-9F6BE85E0D64> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x929e3000 - 0x929e5fff com.apple.securityhi (9.0 - 55005) <87D7FDAE-8D70-3795-B12B-5338CDD5D096> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x929e6000 - 0x92cd6ffc com.apple.CoreImage (9.0.33) <3CB4C13A-7D10-3249-A8DE-45CF7B256C88> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x92cd7000 - 0x92ce5ff7 libz.1.dylib (53) <858B4D9F-D87E-3D81-B07A-DF9632BD185F> /usr/lib/libz.1.dylib
0x92ce6000 - 0x92d7dfff com.apple.Metadata (10.7.0 - 784) <50E22D88-BA08-384E-AAC9-03209FCCFD58> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x92d7e000 - 0x92dbbffb libGLImage.dylib (9.0.77) <41DEC567-B299-36BA-8AFA-C0C7D62C0EC1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x92dbc000 - 0x92dbcfff com.apple.Accelerate.vecLib (3.9 - vecLib 3.9) <D886A622-0221-3CB1-B9EC-CC7C2BDE0E30> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x92dbd000 - 0x92dc6fff com.apple.DiskArbitration (2.6 - 2.6) <56735C75-009E-3981-81FD-4D9EB8A237D1> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x92dc7000 - 0x92dcaffb libutil.dylib (34) <B496031E-E763-3DEB-84D2-85C0F3DF2012> /usr/lib/libutil.dylib
0x92dcb000 - 0x92f76ff1 com.apple.QuartzCore (1.8 - 329.0) <491BC0DC-59AC-35FA-A29C-9A6C633C40DA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x92f77000 - 0x92f81ff2 com.apple.AppSandbox (3.0 - 1) <48B8C715-775E-364A-90A8-22E7CC3EC550> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x92f82000 - 0x92f94fff com.apple.idsfoundation (10.0 - 1000) <118C9FE4-64EE-345C-A6AD-FF99E81DAEAD> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
0x92f95000 - 0x933c9ff7 com.apple.vision.FaceCore (3.0.0 - 3.0.0) <C129CBB0-A9D1-3862-9EB2-F60A20B53DD9> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x933ca000 - 0x933ddfff com.apple.ImageCapture (9.0 - 9.0) <2F63C4A7-C03C-35D7-8252-025E92E13C05> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x933de000 - 0x933e6ffe libGFXShared.dylib (9.0.77) <8E37EDC8-A467-33BD-A75D-82279859D68C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x933e7000 - 0x933e9fff com.apple.SecCodeWrapper (3.0 - 1) <C7B59EAE-52FC-3C95-A2EE-5C115FDD8996> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x933ea000 - 0x9341bffa libsystem_m.dylib (3047.15) <CB1679C0-3D28-32D4-8E7A-F589544C7F9C> /usr/lib/system/libsystem_m.dylib
0x9341c000 - 0x93427ff6 com.apple.NetAuth (5.0 - 5.0) <C317D147-A3D9-3877-8D07-1819B32FBCB2> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x93428000 - 0x9346eff7 libFontRegistry.dylib (122) <B8AA21C0-1D50-3F3B-84EC-E893CA91BC30> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x9346f000 - 0x934cbffa com.apple.print.framework.PrintCore (9.0 - 427) <FE899438-71EF-3D07-9DA5-953E38E334F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x934cc000 - 0x93521ff3 com.apple.ImageCaptureCore (5.0 - 5.0) <CBD9EAF5-4FE4-3002-96D7-339AF4AECE83> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x93522000 - 0x93580ff1 com.apple.AE (665.5 - 665.5) <7A852AD3-D2F4-3F78-A076-DA8673524EE4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x93581000 - 0x93693ffc libsqlite3.dylib (157) <BA5D22E6-5B41-3AB1-B461-247BC03310DE> /usr/lib/libsqlite3.dylib
0x93694000 - 0x936b0fff libCRFSuite.dylib (34) <FFF76EBA-DF35-3A5F-857F-3F4B1C9F4C77> /usr/lib/libCRFSuite.dylib
0x936b1000 - 0x936bdfff com.apple.OpenDirectory (10.9 - 171) <7B8A2E8B-8D79-357B-B96E-65E78E5E3C9F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x936be000 - 0x936ddff9 com.apple.framework.Apple80211 (9.0 - 900.37) <8D6AD961-1F2D-359B-B2CF-70551BB7E7AD> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x936de000 - 0x93749ff6 com.apple.Heimdal (4.0 - 2.0) <ACEC0218-60D1-3CE1-B0FE-86C5FC8E9916> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x9374a000 - 0x937a8ffa com.apple.CoreUtils (1.8 - 180.74) <DDF6A1A2-34C0-3203-9100-71259A81B972> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x937a9000 - 0x9391eff7 com.apple.audio.toolbox.AudioToolbox (1.9 - 1.9) <14A9098B-245A-303D-8030-455A8798F241> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9391f000 - 0x93920fff com.apple.AddressBook.ContactsData (8.0 - 1352.1) <BFF0D843-08AC-344F-B59B-AF9FEA5C2D6C> /System/Library/PrivateFrameworks/ContactsData.framework/Versions/A/ContactsData
0x93921000 - 0x93951ff7 com.apple.CoreServicesInternal (184.3 - 184.3) <1A3A6F13-9B5D-33BE-9253-4367DA7A0067> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x94278000 - 0x946a2ff7 com.apple.MediaToolbox (1.0 - 1273.17) <FDC41A94-3D10-3847-BAB8-A461A3E14603> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x946a3000 - 0x946dbff7 com.apple.MediaKit (15 - 709) <36A44A2E-4DA5-3CD5-9AA5-25FA0C9F26AC> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x946dc000 - 0x9470bff1 com.apple.frameworks.CoreDaemon (1.3 - 1.3) <B6CEF057-A2A9-34C4-853A-4FFADB83199E> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x9470c000 - 0x948d2ff9 libicucore.A.dylib (511.22) <E61F66C8-75EE-37D4-B292-FCADD6420DF4> /usr/lib/libicucore.A.dylib
0x948d3000 - 0x948d5fff libquarantine.dylib (71) <02CC9B86-7B90-3108-AD00-94A871641905> /usr/lib/system/libquarantine.dylib
0x948d6000 - 0x94bd6ff1 com.apple.AOSKit (1.06 - 170) <0E3F1AB4-A577-3C99-9019-3168AF923371> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
0x94ce0000 - 0x9524dfff com.apple.QuartzComposer (5.1 - 316) <424B424E-F092-3D3C-9517-F3E4702DE259> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x9524e000 - 0x95256ff7 libCGCMS.A.dylib (577.1) <366A7740-DF41-3FF9-B673-87A1E9814D29> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0x95260000 - 0x952d5ffb com.apple.framework.IOKit (2.0.1 - 907.1.7) <8C526A57-1B3E-3349-814F-2E2C3B616A90> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x952d6000 - 0x95605ffc com.apple.Foundation (6.9 - 1047.1) <C1621C3A-C928-3F6D-A40F-1EA60CF150E5> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x95606000 - 0x9561bff3 com.apple.AppContainer (3.0 - 1) <100C486E-74F5-3BD4-A841-E834F74368A9> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x9561c000 - 0x95760ffd com.apple.avfoundation (2.0 - 651.7) <2C9F9F93-7549-3A18-9AC5-644F39659BFB> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x95761000 - 0x95789fff libsystem_info.dylib (449.1.2) <12AFC6C8-3AEC-36B5-BD4F-49E04F81C26C> /usr/lib/system/libsystem_info.dylib
0x9578a000 - 0x9579eff9 com.apple.MultitouchSupport.framework (245.13 - 245.13) <D86A9864-BCBE-35FA-9AF9-5C2C37F3AE79> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x9579f000 - 0x958f5ff0 libBLAS.dylib (1094.5) <74310C2F-4FDB-3995-A01A-5AFB83010A43> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x958f6000 - 0x958f9ff3 com.apple.AppleSystemInfo (3.0 - 3.0) <03C958AA-47FC-3AE4-B261-CAAF1E555F7E> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x958fa000 - 0x95953ffa libTIFF.dylib (1033) <796401D6-95E8-301F-9D93-C5F09DA62EE9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x95954000 - 0x95afc50f libobjc.A.dylib (551) <E9DB6B68-3B38-3558-86BD-65B7F0825DC4> /usr/lib/libobjc.A.dylib
0x95afd000 - 0x95ec2ff6 libLAPACK.dylib (1094.5) <E6286E68-3501-31AC-813E-75B3B3968011> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x95ec3000 - 0x95f36ff7 com.apple.SearchKit (1.4.0 - 1.4.0) <30C0C84C-B1DE-36AD-8DBE-6297D7464796> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x95f37000 - 0x95f40ff9 com.apple.CommonAuth (4.0 - 2.0) <BDF11644-563A-3D5D-AC01-22AE497C4C95> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x95f41000 - 0x95f5effb libresolv.9.dylib (54) <3EC12A7F-6BA1-3976-9F1F-6A4B76303028> /usr/lib/libresolv.9.dylib
0x95f5f000 - 0x95f63ffa libcache.dylib (62) <141F780B-0D05-3C86-8BCF-7D1C0D6BAE0A> /usr/lib/system/libcache.dylib
0x95f64000 - 0x95fb9fff libc++.1.dylib (120) <4599B3C0-DE83-32F3-B72C-FF4BD6489784> /usr/lib/libc++.1.dylib
0x95fba000 - 0x95fc8fff libxar.1.dylib (202) <B73748D4-F830-3C71-98B3-7A3ABF5136FD> /usr/lib/libxar.1.dylib
0x95fc9000 - 0x95fc9fff com.apple.Cocoa (6.8 - 20) <3A45C71C-C849-31C8-9407-E436998D6975> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x95fca000 - 0x95fd5fff libGPUSupportMercury.dylib (9.0.77) <B6178767-823D-3B34-866E-334A20348F06> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x95fd6000 - 0x9602affa com.apple.Suggestions (3.0 - 132.0) <D38BD983-2086-36B8-938F-5F0EBFC7633A> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
0x9602b000 - 0x96033fff liblaunch.dylib (842.1.1) <8E6395F5-F320-3E39-BABB-82242B12A22D> /usr/lib/system/liblaunch.dylib
0x96034000 - 0x9631efd2 com.apple.vImage (7.0 - 7.0) <15B6239E-17BB-39A5-8541-080255F078A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x9631f000 - 0x96373ff7 com.apple.audio.CoreAudio (4.2.0 - 4.2.0) <D2B1CDC9-4F13-371B-A34D-F173B79D9C91> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x96374000 - 0x96375fff libDiagnosticMessagesClient.dylib (100) <B936B1D4-90BB-395D-8EA9-E1237608E7D0> /usr/lib/libDiagnosticMessagesClient.dylib
0x96376000 - 0x9639bff7 com.apple.quartzfilters (1.8.0 - 1.7.0) <FEEC2F07-D1B7-3571-9FDB-7B0BBE590FF2> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x9639c000 - 0x963d8ff4 com.apple.RemoteViewServices (2.0 - 94) <68B43E56-7533-3E13-B703-F57FC600F1DE> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x963d9000 - 0x963ddfff com.apple.CommonPanels (1.2.6 - 96) <691368C7-65DD-34F4-95CF-B1412363F17E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x963de000 - 0x96454ff3 com.apple.securityfoundation (6.0 - 55122) <453FD317-C386-3A96-A1B5-3E65FC3E73C4> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x96455000 - 0x964daffc com.apple.CorePDF (4.0 - 4) <0D255518-C5A4-3354-9E73-F61BA09E19D3> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x964db000 - 0x96739fff com.apple.AddressBook.framework (8.0 - 1352.1) <DE614801-2053-3A15-A99A-A2157ACE29AD> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x9673a000 - 0x96758fff com.apple.facetimeservices (10.0 - 1000) <B416F2B1-4BD1-3C22-9319-F1912EBF678A> /System/Library/PrivateFrameworks/FTServices.framework/Versions/A/FTServices
0x96759000 - 0x967c3ff7 com.apple.framework.CoreWiFi (2.0 - 200.21.1) <611D58B5-AAD2-38DD-B78E-99E6576A69E2> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x967c4000 - 0x967f6ffb com.apple.CoreAVCHD (5.7.0 - 5700.4.3) <2FE36C7B-5B2B-30DC-B4A3-0B40D6CAF3D7> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
0x967f7000 - 0x96822ff5 com.apple.ChunkingLibrary (2.0 - 155.1) <3F5921BF-33FA-3F87-B0EA-F892C2AA1CF6> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x96823000 - 0x9683cfff com.apple.Kerberos (3.0 - 1) <2148D8D0-BADB-3C68-A53F-B93E2E791ACA> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x9683d000 - 0x96841fff libheimdal-asn1.dylib (323.8) <24AD4F4F-8656-3E5A-9C4C-4AF2B955DD27> /usr/lib/libheimdal-asn1.dylib
0x96842000 - 0x96859ff2 com.apple.CoreMediaAuthoring (2.2 - 946) <07EA767A-6EA5-3C35-A060-FF13F5940F9E> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x9685a000 - 0x96864fff com.apple.bsd.ServiceManagement (2.0 - 2.0) <CD3C048F-8E40-3230-A3BC-B09464A6CC9F> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x96865000 - 0x968baff7 com.apple.QuickLookFramework (5.0 - 615.0) <32E16E76-66B7-3DC8-878A-A81A33913F86> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x96970000 - 0x96971ffa libsystem_sandbox.dylib (278.5) <498CBFD8-BD6C-3392-A4D5-5B6588033A7C> /usr/lib/system/libsystem_sandbox.dylib
0x96972000 - 0x96d27fff com.apple.FinderKit (1.2 - 1.2) <469C4599-B990-392D-8E03-F0DCB4339AAD> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
0x96d28000 - 0x96d42ff7 com.apple.GenerationalStorage (2.0 - 159) <48BD83EA-2665-3E3B-A3A7-995E0E8AFEED> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x96d43000 - 0x96d91ff9 com.apple.HIServices (1.22 - 459) <C24434CE-CF86-3AC5-A3E0-534EAB980004> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x96d92000 - 0x97093ff3 com.apple.CoreServices.CarbonCore (1077.7 - 1077.7) <25700B2A-CB3A-3F94-9C4A-54A723C79D63> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x97094000 - 0x97109ff1 com.apple.ApplicationServices.ATS (360 - 361) <3E5C6D46-B454-388D-86F5-A839B7039729> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9710a000 - 0x971effff com.apple.coreui (2.1 - 228.1) <7C23FDC1-436A-3679-AD78-0342C82E92B7> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x971f0000 - 0x97270ff7 com.apple.CoreServices.OSServices (600.2 - 600.2) <E9CFB58D-309E-3E72-A7F1-7B5D961BCBAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x97271000 - 0x972d7ff4 com.apple.ISSupport (1.9.9 - 57) <0B124F83-4717-3048-90C8-FE9374D23CC0> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
0x972d8000 - 0x972e5ff7 com.apple.AppleFSCompression (56 - 1.0) <CDFB1F7A-75BF-324E-B51D-DA6F81133529> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x972e6000 - 0x97725fe3 com.apple.VideoToolbox (1.0 - 1273.17) <0521ADD1-6D75-3486-ACC1-A0F56AEAB50D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x97726000 - 0x977c2fff com.apple.QD (3.49 - 297) <F2E795FD-A795-35C6-B4F9-7DB5CB6F1302> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x977c3000 - 0x977ccfff libsystem_notify.dylib (121) <E744DD94-D76D-3B7E-800D-4F0AEF411E5F> /usr/lib/system/libsystem_notify.dylib
0x977cd000 - 0x977f8ff7 libpcap.A.dylib (42) <66FBEAD3-FE91-3A89-8706-FB95229068AC> /usr/lib/libpcap.A.dylib
0x977f9000 - 0x97a57fff com.apple.CoreData (107 - 474) <8F67933F-C0F9-3354-80EA-4CE3FFCB065F> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x97a58000 - 0x97a5afff libsystem_configuration.dylib (596.5) <FA56DBED-6EF5-3377-BA32-C9E16C9B1889> /usr/lib/system/libsystem_configuration.dylib
0x97a5b000 - 0x97a65fff com.apple.DirectoryService.Framework (10.9 - 171) <C419D21A-428B-3EFC-A750-5C6C08C4552C> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x97a66000 - 0x97a9efff com.apple.LDAPFramework (2.4.28 - 194.5) <4F85B3A5-0968-3DA5-812F-F321947424BA> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x97a9f000 - 0x97adcff4 com.apple.ids (10.0 - 1000) <7A65D617-AE26-3256-B873-E6AAFE96F6AF> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
0x97add000 - 0x97ae3ff7 com.apple.AddressBook.ContactsFoundation (8.0 - 1352.1) <419ADB9F-6013-34B3-B54C-7945B99AE6D0> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundation
0x97ae4000 - 0x97d60ff7 com.apple.QuickTime (7.7.3 - 2814) <BEF0EFAE-6978-3ACE-9281-0E979F1B7874> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x97d61000 - 0x97d7ffff com.apple.frameworks.preferencepanes (16.0 - 16.0) <4D78E0A7-1414-3435-8468-83D490EC6971> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
0x97d80000 - 0x97febff1 com.apple.security (7.0 - 55397) <86634D8D-B39E-365C-8B8B-6D2FCA754561> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x97fec000 - 0x980cfff7 libcrypto.0.9.8.dylib (50) <40B3B8F7-3CEC-30FE-B8AF-D480849D019F> /usr/lib/libcrypto.0.9.8.dylib
0x980d0000 - 0x9816fff7 libCoreStorage.dylib (379) <84CE3982-A58F-39CA-BD97-D81DBB1D11D5> /usr/lib/libCoreStorage.dylib
0x98170000 - 0x9818dffc libsystem_kernel.dylib (2422.1.43) <F17D4E5D-BA77-3FA3-8132-3554A752C9FF> /usr/lib/system/libsystem_kernel.dylib
0x9818e000 - 0x98192ffc com.apple.IOSurface (91 - 91) <A8B02FE2-2E63-3140-BDAC-80DFC9FEF0A7> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x98193000 - 0x98196ff7 com.apple.help (1.3.3 - 46) <E809F9FD-B16D-3047-AEAA-A0CF0BD98E99> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x98197000 - 0x9819ffff libcopyfile.dylib (103) <9CD2FD34-F457-3550-8589-FB9CC31C2F8D> /usr/lib/system/libcopyfile.dylib
0x981a0000 - 0x981a6ffb libunwind.dylib (35.3) <E2CEC446-9F54-3B1D-B30F-14B5A8F66569> /usr/lib/system/libunwind.dylib
0x981a7000 - 0x981fdff6 com.apple.ScalableUserInterface (1.0 - 1) <3176249E-C49D-321D-AF46-637DFA118865> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x981fe000 - 0x983ffff7 com.apple.CoreFoundation (6.9 - 847.11) <A2429A16-AD7A-3886-9A8B-158C6B6C28A4> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x98400000 - 0x98417ff7 com.apple.CFOpenDirectory (10.9 - 171) <017B43FB-EA82-392C-BBF0-34575737F554> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x98418000 - 0x98419ffc com.apple.TrustEvaluationAgent (2.0 - 25) <064B485D-56E0-3DD7-BBE2-E08A5BFFF8B3> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x9841a000 - 0x9844aff3 libtidy.A.dylib (15.12) <3DBE95FE-8FA7-3584-9202-E37B54B3B064> /usr/lib/libtidy.A.dylib
0x9844b000 - 0x9844effa libCGXType.A.dylib (577.1) <FA86FC26-CE75-376C-9499-9E2ECF385A83> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x9844f000 - 0x9854dfff libJP2.dylib (1033) <33441E70-B56A-3ACE-8EE1-FEBD53D7E006> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x9854e000 - 0x9854ffff libsystem_blocks.dylib (63) <24756BCA-625E-3B4D-B635-9913575E6534> /usr/lib/system/libsystem_blocks.dylib
0x98550000 - 0x98554fff com.apple.IOAccelerator (98.4 - 98.4) <CB93B322-4AC8-3F56-AFC7-2803B4755844> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x98555000 - 0x9855cff4 com.apple.NetFS (6.0 - 4.0) <322E5505-D41B-37C5-A2DD-28B109F9110C> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x9855d000 - 0x9855dfff libkeymgr.dylib (28) <10888F53-8E42-38FB-8643-6CDBC886AB59> /usr/lib/system/libkeymgr.dylib
0x9855e000 - 0x98581ff7 libxpc.dylib (300.1.9) <577B27DA-70C9-361C-A6B7-9E60DE903FF5> /usr/lib/system/libxpc.dylib
0x98582000 - 0x985e8ffc com.apple.framework.CoreWLAN (4.0 - 400.39) <69D70C64-7675-3212-B6E0-8621F226D21B> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x985e9000 - 0x98613fff libxslt.1.dylib (13) <ED6AFBE8-E19E-36FF-86D2-634535D79EFD> /usr/lib/libxslt.1.dylib
0x98614000 - 0x98617fff libdyld.dylib (239) <C6DE4E47-FF4A-30EC-84A8-F50FCA5CDF24> /usr/lib/system/libdyld.dylib
0x98618000 - 0x986beff7 com.apple.imcore (10.0 - 1000) <7EFE52CE-9D71-37E0-853E-84C51E5809A0> /System/Library/PrivateFrameworks/IMCore.framework/Versions/A/IMCore
0x986bf000 - 0x98711ff7 com.apple.framework.internetaccounts (2.1 - 210) <9446DB6D-4CE2-3DF2-836B-D44DDB51C31A> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
0x98712000 - 0x98719ff7 com.apple.XPCService (2.0 - 1) <EEF1A555-9231-373E-967F-63B1BD48D084> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x9871a000 - 0x9874fffd libssl.0.9.8.dylib (50) <F3BEA2DF-DB84-37F0-B4C7-97C0A4DF19C9> /usr/lib/libssl.0.9.8.dylib
0x98750000 - 0x98840ffb libiconv.2.dylib (41) <848FEBA7-2E3E-3ECB-BD59-007F32468787> /usr/lib/libiconv.2.dylib
0x9884f000 - 0x988e0fff com.apple.ColorSync (4.9.0 - 4.9.0) <A22E97CD-4140-3F20-97BA-CB862F801325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x988e1000 - 0x988e1fff com.apple.quartzframework (1.5 - 1.5) <45E48490-E2D6-338D-96F9-FAF28CA5274D> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x988e2000 - 0x988fbff7 libAVFAudio.dylib (32.1) <92D831C5-5DEA-337C-9892-9560BAA69F0E> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Resources/libAVFAudio.dylib
0x988fc000 - 0x98da3fe7 com.apple.CoreAUC (6.22.08 - 6.22.08) <2E922C9C-15B2-3E52-BAA5-681452C42823> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x98da4000 - 0x98e50ffb libvMisc.dylib (423.31) <68F8AF33-6322-3199-BC94-42C8539756B2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x98e51000 - 0x98e99fff com.apple.PerformanceAnalysis (1.47 - 47) <F63E9311-3CB5-30AE-AB1E-997BCF80738A> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x98e9a000 - 0x98e9fff7 com.apple.print.framework.Print (9.0 - 260) <73BB22F4-618B-3AE0-AF3F-4DA323F32000> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x98ea2000 - 0x98f39ff7 com.apple.ink.framework (10.9 - 206) <EEF9C4C6-C074-3168-9223-3C382200133C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x98f3a000 - 0x98f46ffe libkxld.dylib (2422.1.43) <C08FB2E5-E285-3E5F-9C3A-F05C73B95074> /usr/lib/system/libkxld.dylib
0x98f47000 - 0x98f6fff7 libRIP.A.dylib (577.1) <9C699E9C-C167-3E0C-A9BF-3F7C7B832677> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x98f70000 - 0x98f70fff com.apple.Accelerate (1.9 - Accelerate 1.9) <4F47CD46-E644-3E71-ABE5-F22DBB64DE63> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x98f71000 - 0x98f75ff7 libmacho.dylib (845) <386D2717-B26E-3DA0-9E5F-4415832BB60D> /usr/lib/system/libmacho.dylib
0x98f76000 - 0x98f86ff7 libsasl2.2.dylib (170) <F10052F0-C455-37A6-8346-4DF1F8D533E4> /usr/lib/libsasl2.2.dylib
0x98f87000 - 0x98f87fff com.apple.ApplicationServices (48 - 48) <82DEEF76-E5CB-35DF-B4DB-985690AAC1D6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x98f88000 - 0x98fa4ff9 com.apple.Ubiquity (1.3 - 286) <0C38E45F-BE5D-36CE-BC07-AD1A627BD7C9> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x98fa5000 - 0x98fbbff9 com.apple.aps.framework (4.0 - 4.0) <2D89CFCD-5CCE-387E-BA62-5F833355775C> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x98fbc000 - 0x99045ff7 com.apple.CoreSymbolication (3.0 - 140) <2C1FF63A-1A4B-3772-9E0C-7680469BF503> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x99070000 - 0x9909afff libsandbox.1.dylib (278.5) <A769E4E2-744C-3238-9201-6E5DD1F0CEC6> /usr/lib/libsandbox.1.dylib
0x9909b000 - 0x990ddfff libGLU.dylib (9.0.77) <624F7685-A4E1-312B-B198-7C4DF8BEBEAB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x990de000 - 0x991caff7 libxml2.2.dylib (26) <09AF509D-F150-3A05-BB25-12153EB8FA51> /usr/lib/libxml2.2.dylib
0x991cb000 - 0x991f6ff7 libsystem_network.dylib (241.3) <62713985-C046-3D8A-A308-3A413FA61600> /usr/lib/system/libsystem_network.dylib
0x991f7000 - 0x99202ff8 com.apple.CrashReporterSupport (10.9 - 533) <C57CC560-1EE9-3D02-85F4-CB5439DB4601> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x99203000 - 0x9920bfff libsystem_dnssd.dylib (522.1.9) <545B3447-1F5F-3C33-81D7-81BAC8654283> /usr/lib/system/libsystem_dnssd.dylib
0x9920c000 - 0x9920eff2 com.apple.EFILogin (2.0 - 2) <B9DFA799-B39C-3AD5-9C10-B8FD468AC109> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x9920f000 - 0x9922aff6 libPng.dylib (1033) <46174242-D184-3EE0-839F-78121D27ED51> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x9922b000 - 0x99230ff3 libsystem_platform.dylib (24.1.3) <6CCD884E-0F4A-3641-B2AE-C12AF0105E15> /usr/lib/system/libsystem_platform.dylib
0x99231000 - 0x99231ffd libOpenScriptingUtil.dylib (154) <754BE8EF-4253-3679-8691-41F9B7C7BEC8> /usr/lib/libOpenScriptingUtil.dylib
0x99232000 - 0x99238ff7 com.apple.AOSNotification (1.7.0 - 760.2) <D2998174-BCB4-38E1-8818-A4F60BDA403C> /System/Library/PrivateFrameworks/AOSNotification.framework/Versions/A/AOSNotification
0x99239000 - 0x99e46ff1 com.apple.AppKit (6.9 - 1244.12) <EF2A2190-F6B1-3A22-867C-CEBDD1A875D5> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x99e4e000 - 0x9a0abffb com.apple.RawCamera.bundle (4.07 - 700) <48C09A49-A720-3AFE-AD35-AFC53EA5631B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x9a0ac000 - 0x9a0d3fff com.apple.CoreVideo (1.8 - 117.2) <39DF72AB-3BCF-3EEC-B4C6-728043B8C89C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x9a0d4000 - 0x9a1e0ff8 com.apple.MediaControlSender (1.8 - 180.74) <2E4AA539-E3B0-3939-B1A0-7E6F11AD3BF9> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSender
0x9a258000 - 0x9a26afff libsystem_asl.dylib (217.1.1) <CB60A575-F6DA-3E1F-B7CF-9182170CD2E2> /usr/lib/system/libsystem_asl.dylib
0x9a26b000 - 0x9a2d4ff5 com.apple.datadetectorscore (5.0 - 347.0) <5C56A097-E40F-3BC7-A807-A17FCCC2914D> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x9a2d5000 - 0x9a325ff7 libcorecrypto.dylib (161.1) <135FD99E-2211-3DF4-825C-C9F816107F0C> /usr/lib/system/libcorecrypto.dylib
0x9a326000 - 0x9a32affe libCoreVMClient.dylib (58.1) <2F451BE5-F847-31A6-A579-A66DCA0280E7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x9a32b000 - 0x9a332ff1 com.apple.phonenumbers (1.1.1 - 105) <B0CCF50F-86A6-36CC-8732-14E76226EC27> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x9a333000 - 0x9a72bfff com.apple.CoreGraphics (1.600.0 - 577.1) <838BFDDE-6364-3F1E-AF0B-BFE5D3909EB4> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9a72c000 - 0x9a7fcfef libvDSP.dylib (423.31) <15E9C4E7-6571-3827-B9A2-6BF0172FBC63> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x9a830000 - 0x9a897ffb com.apple.CoreMedia (1.0 - 1273.17) <21933DE9-0A80-30CA-9008-031D2933C634> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x9a898000 - 0x9a92affe libsystem_c.dylib (997.1.1) <3CD40E0C-A046-3DCA-A440-DE45B1CA615A> /usr/lib/system/libsystem_c.dylib
0x9a92b000 - 0x9a93dfff libbsm.0.dylib (33) <1BE92DB5-0D2F-3BB5-BCC6-8A71EF2A3450> /usr/lib/libbsm.0.dylib
0x9a93e000 - 0x9a96cff3 com.apple.DebugSymbols (106 - 106) <5E461A7E-F2FC-3242-AB44-1F5997420222> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x9a96d000 - 0x9a971ffc libpam.2.dylib (20) <50623D44-795F-3E28-AA85-23E0E7E2AE0E> /usr/lib/libpam.2.dylib
0x9a972000 - 0x9a972ffd com.apple.audio.units.AudioUnit (1.9 - 1.9) <238536D4-7BB5-3069-B835-3E5A9D1D7C48> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9a973000 - 0x9a973fff com.apple.CoreServices (59 - 59) <E3C0E17C-EB66-3378-B3F1-828FFBC93A11> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x9a974000 - 0x9a9ddff7 com.apple.SystemConfiguration (1.13 - 1.13) <30EA2CB9-67FC-369C-8605-6D62A6033FF9> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x9a9de000 - 0x9a9e7fff com.apple.speech.recognition.framework (4.2.4 - 4.2.4) <BC075D95-0F76-3E5E-B161-91ED7CE5ECCA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x9a9e8000 - 0x9aa00ffe libsystem_malloc.dylib (23.1.7) <A0A7DD06-6C42-3F20-8EB8-58D41A0730C5> /usr/lib/system/libsystem_malloc.dylib
0x9aa01000 - 0x9aa24ff7 libc++abi.dylib (47.1) <693F519E-E281-3670-A1D7-5B6A63CEA448> /usr/lib/libc++abi.dylib
0x9aa25000 - 0x9ad98ff9 com.apple.HIToolbox (2.1 - 686) <34773C44-AF6D-352C-B368-D125918F72E1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x9ad99000 - 0x9adf9ffb com.apple.imfoundation (10.0 - 1000) <9C14BFF6-C0AA-33F6-B5B8-6384287642D8> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
0x9adfa000 - 0x9ae4dff3 com.apple.CoreMediaIO (401.0 - 4540) <F9469286-565A-30EF-8D30-C26F6F66D771> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x9ae4e000 - 0x9aea1fff com.apple.htmlrendering (77 - 1.1.4) <3DA9E017-7782-38E2-8857-3105F6357349> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 3
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 12820
thread_create: 1
thread_set_state: 57
VM Region Summary:
ReadOnly portion of Libraries: Total=311.6M resident=144.1M(46%) swapped_out_or_unallocated=167.5M(54%)
Writable regions: Total=294.0M written=118.8M(40%) resident=37.6M(13%) swapped_out=102.3M(35%) unallocated=256.4M(87%)
REGION TYPE VIRTUAL
CG backing stores 14.3M
CG image 160K
CG raster data 596K
CG shared images 204K
IOKit 20.5M
IOKit (reserved) 4K reserved VM address space (unallocated)
Kernel Alloc Once 4K
MALLOC 251.9M
MALLOC (admin) 48K
Memory Tag 241 124K
Memory Tag 242 12K
OpenCL 128K
OpenGL GLSL 1280K
Stack 65.1M
VM_ALLOCATE 16.7M
__DATA 30.2M
__IMAGE 528K
__LINKEDIT 36.8M
__OBJC 3892K
__PAGEZERO 4K
__TEXT 274.8M
__UNICODE 544K
mapped file 147.6M
shared memory 68K
TOTAL 865.3M
TOTAL, minus reserved VM space 865.3M
Model: MacBookPro10,1, BootROM MBP101.00EE.B02, 4 processors, Intel Core i7, 2.3 GHz, 8 GB, SMC 2.3f35
Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In, 1024 MB
Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1024 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533642465238432D50422020
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x80AD, 0x484D54333531533642465238432D50422020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xEF), Broadcom BCM43xx 1.0 (5.106.98.100.19)
Bluetooth: Version 4.2.0b18 12683, 3 services, 13 devices, 3 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM256E, 251 GB
USB Device: USB 3.0 HUB
USB Device: USB to ATA/ATAPI Bridge
USB Device: Hub
USB Device: MT1956
USB Device: FaceTime HD Camera (Built-in)
USB Device: Hub
USB Device: Hub
USB Device: Apple Internal Keyboard / Trackpad
USB Device: BRCM20702 Hub
USB Device: Bluetooth USB Host Controller
USB Device: USB 2.0 HUB
USB Device: Ext HDD 1021
USB Device: Hub
USB Device: My Book 1110
USB Device: My Book
Thunderbolt Bus: MacBook Pro, Apple Inc., 23.4, 0x100, 0.12.3, 0x100, 0.12.3
marshalleq
Post by marshalleq »
I can confirm still happening on 10.9 DP6 and MakeMKV 1.8.4.
Thought it was the disc then realised it just happens after a random period of time, even if not ripping.
Debug log started at Sat Aug 24 05:12:12 2013 , written by MakeMKV v1.8.4 darwin(x86-release)
001005:0000 MakeMKV v1.8.4 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/username/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE HL-DT-ST BD-RE BH10LS30 1.01d" opened in OS access mode.
csft i=3 t=1377321187152
csft i=4 t=1377321188158
csft i=5 t=1377321189165
csft i=6 t=1377321190172
csft i=7 t=1377321191179
csft i=8 t=1377321192186
csft i=9 t=1377321193192
csft i=3 t=1377321197200
csft i=4 t=1377321198206
csft i=5 t=1377321199213
csft i=6 t=1377321200220
csft i=7 t=1377321201226
csft i=8 t=1377321202233
csft i=3 t=1377321207226
csft i=4 t=1377321208226
csft i=5 t=1377321209233
csft i=6 t=1377321210239
csft i=7 t=1377321211246
csft i=8 t=1377321212252
csft i=9 t=1377321213259
csft i=10 t=1377321214266
csf8
csf6
Application exited at Sat Aug 24 05:13:34 2013
marshalleq
Actually just got the same error on Windows. No log so not sure if it's exactly the same, but it may be not Mac related.
