Keep getting this error message.
Cheddar
Post by Cheddar »
I ripped a Blu-ray of a TV series.
No suitable decoder module:
VLC does not support the audio or video format "undf". Unfortunately there is no way for you to fix this.
I have video but no audio at all.
Romansh
Re: Keep getting this error message.
Post by Romansh »
Use the FLAC conversion profile for Blu-rays with LPCM audio. You need to enable expert mode in preferences.
Cheddar
Post by Cheddar »
Romansh wrote:Use the FLAC conversion profile for Blu-rays with LPCM audio. You need to enable expert mode in preferences.
Where is LPCM audio?
Romansh
Post by Romansh »
Don't have one available right now. Here's an example, except it has DTS-HD Lossless instead of LPCM (you don't need to use the FLAC profile for DTS-HD to get audio in VLC, though VLC will only decode the lossy DTS "core"):
Cheddar
Post by Cheddar »
Romansh wrote:Don't have one available right now. Here's an example, except it has DTS-HD Lossless instead of LPCM (you don't need to use the FLAC profile for DTS-HD to get audio in VLC, though VLC will only decode the lossy DTS "core"):
Thanks for your help, I now have audio. But for some reason it wont play in my Sony BDP-S580 Blu-ray player and it only supports MPEG-4 AVC
*1*2, any way MakeMKV will do it this way?
austingrd
Post by austingrd »
Looks like this is a non standard MKV file. Check this conversation.
viewtopic.php?f=8&t=3886&p=14788&hilit=undf#p14788
Mistakes are learning tools. Image
Cheddar
Post by Cheddar »
austingrd wrote:Looks like this is a non standard MKV file. Check this conversation.
What do u mean?
