Can't Rip and OLD DVD
Dirtydeedz
Post by Dirtydeedz »
I thought maybe it was the old DVD just being "Old". A few scratches here and there; but, it still plays fine. Then I read the forums here and it looks like others have similar issues. And I was able to rip it w/ some other software. But, I wana rip it w/ MakeMKV because it's the best :wink: And, it's lossless. I have tried to rip this particular WB DVD w/ MakeMKV on 2 of my machines w/ different LG BR Burners and I get the same result.
Debug log started at Tue Jun 18 03:54:31 2013 , written by MakeMKV v1.8.3 win(x64-release)
001005:0000 MakeMKV v1.8.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Dirtydeedz/MakeMKV_log.txt
003028:0000 Title #1 was added (14 cell(s), 1:26:19)
003025:0000 Title #2 has length of 19 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #3 has length of 32 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003028:0000 Title #4 was added (1 cell(s), 0:22:09)
003025:0000 Title #5 has length of 272 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #6 has length of 264 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #7 has length of 64 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #8 has length of 149 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #9 has length of 19 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003028:0000 Title #10 was added (7 cell(s), 0:13:29)
003028:0000 Title #11 was added (7 cell(s), 0:13:29)
003025:0000 Title #12 has length of 80 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003025:0000 Title #13 has length of 52 seconds which is less than minimum title length of 300 seconds and was therefore skipped
003030:0000 Subtitle stream #3 is identical to stream #2 and was skipped
003030:0000 Subtitle stream #4 is identical to stream #2 and was skipped
001003:0020 DEBUG: Code 233 at DdpmMZ2+5U6Cnz7hxEylcJBk:0
005014:0000 Saving 1 titles into directory F:/CD & DVD Images/MKV
AV sync issues in F:/CD & DVD Images/MKV/SCOOBY_DOO_t00.mkv
AV sync in 1 at 0:00:00.005 (32ms) : 1 early frame(s) dropped at start
001003:0020 DEBUG: Code 3221225628 at E8Yf=#%2TA".E&D-m{Ucgb:]N:121263521
001003:0020 DEBUG: Code 3221225628 at :{{ywB\[=QH)OiU*:29393953
001003:0020 DEBUG: Code 2 at j|^%K#]b@6Ui^94k:213137827
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1748303872'
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1748533248'
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1748893696'
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1749483520'
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1752891392'
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1753120768'
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1753251840'
001003:0020 DEBUG: Code 0 at zt,@d\<Ndg?s4#yhpphw:121262739
001003:0020 DEBUG: Code 0 at A/yL|-y2hd+dppl?ZEW:121261681
001003:0020 DEBUG: Code 0 at zt,@d\<Ndg?s4#yhpphw:213130743
001003:0020 DEBUG: Code 856080 at zt,@d\<Ndg?s4#yhpphw:29393332
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1753481216'
001003:0020 DEBUG: Code 856192 at zt,@d\<Ndg?s4#yhpphw:29393332
001003:0020 DEBUG: Code 0 at sK+=D=hBb-D_SJ7nc\H0.:29398645
001003:0020 DEBUG: Code 0 at '2LybnZU-par6!%.">D:213132744
FS ID=<FAILED> C=0
TI=ZeNpjZBjcAAABQAAC
001003:0020 DEBUG: Code 0 at _,GSpkKz8yCU>_X*r:121263728
001003:0020 DEBUG: Code 0 at _,GSpkKz8yCU>_X*r:121263176
001003:0020 DEBUG: Code 0 at _,GSpkKz8yCU>_X*r:29393930
001003:0020 DEBUG: Code 0 at sK+=D=hBb-D_SJ7nc\H0.:29399013
005003:0000 Failed to save title 0 to file F:/CD & DVD Images/MKV/SCOOBY_DOO_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Tue Jun 18 04:08:57 2013
MakeMKV_log.txt
Debug Log
(14.17 KiB) Downloaded 628 times
crowfax
Re: Can't Rip and OLD DVD
Post by crowfax »
Chances are the disc is damaged / dirty or poorly pressed. However as it's a DVD there is a small chance it's a structural copy protection issue. Please take the steps for sending the IFO files as described here:
/faq/item/8
Dirtydeedz
crowfax wrote:Chances are the disc is damaged
Spot on crowfax. MakeMKV finally worked after the 25th or 26th time in the Memorex OptiFix Pro :mrgreen: :oops:
Of course, the last two "Repair" Cycles I held pressure on the lid of the OptiFix w/ my thumbs :!:
Sorry for the confusion.
Smithcraft
Post by Smithcraft »
Just because a disc can be played, does not mean it can be ripped. Ripping is more strict than playing, so there if there are excessive problems with the media it can't be ripped.
You could perhaps try taking the disc to a DVD rental place and see if they can polish it for you. That might make it rip-able if it's only a problem with the surface and not the substrate.
SC
