Just copied Enchanted Bluray and instead of taking up the fullscreen it creates a smaller, but proportional, window.
Is this an issue or do I need to change a setting somewhere?
Screenshot attached
Many thanks
Paul
Wrong screen size
Twowit2woo
Wrong screen size
- Enchanted.png (389.84 KiB) Viewed 8811 times
Smithcraft
Re: Wrong screen size
There is no setting in MakeMKV to change as it's just taking the streams from the disc and putting them in a new container.
However, VLC might be scaling, so try checking the Video menu, and select the normal size option.
SC
SC
Twowit2woo
It was actually when I played it on the telly that I noticed. I just chucked it in VLC for the purposes of a screenshot.However, VLC might be scaling
I actually decided to sit and watch it because I was curious, and oddly this is actually how the original film plays (to my surprise.)
It starts off in widescreen, then goes to that "view" (black around all edges), then goes back to widescreen again. Not quite sure why this is - seems a bit odd to me.
Never mind - at least my mind is put at rest that the version I have is true to the original
Thanks for the help.
