Linux Mint
marco2often
Linux Mint
Post by marco2often » Tue May 28, 2013 2:06 pm
I managed to install MakeMKV on Linux Mint (14), which is based on Ubuntu.
The instructions on this website did not work; I used the Ubuntuforum (http://askubuntu.com/questions/140080/p ... -using-vlc) to find an update; only I needed to modify the versionnumber of MakeMKV in the script. I downloaded the files from this site and changed the directorynumbers to the version used in the script. I managed to see the content of a blueray disk produced in 2012 and purchased by me. I was unable to watch this until I came across this program. So thank you!
austingrd
Re: Linux Mint
Post by austingrd » Fri Jun 14, 2013 11:54 pm
hi Marco, any updates on this yet? Try this tutorial and hope it works out fine for you.
http://closingthedrapes.blogspot.com/20 ... -mint.html
Mistakes are learning tools. Image
tabish121
Re: Linux Mint
Post by tabish121 » Sat Jun 15, 2013 10:31 am
I install it on my Mint system using this great script makemkv-install
https://www.ebower.com/docs/ubuntu-bluray/#MakeMKV
There's instructions for adding the repo to your system so you can just apt-get install it.
