3D coming out as 2D
tommytinkroom
3D coming out as 2D
Post by tommytinkroom »
Trying to convert Monster vs Alien 3D but fininshed file comes out as 2D.
Grateful for any help. :?
twa000
Re: 3D coming out as 2D
Post by twa000 »
Have you ticked the MVC box?
tommytinkroom
twa000 wrote:Have you ticked the MVC box?
Yes,i had it ticked.
ltm82
Post by ltm82 »
what did you have used to play the file?
tommytinkroom
ltm82 wrote:what did you have used to play the file?
I'm trying to play it back on the mede8er MED1000X3D.I tried again
and i relized i made a mistake and on the MED1000X3D i should have
pressed the menu during playback which gives you the 3D options,also
on the MED1000X3D forum there was a tutorial which suggested changing
the file name to 3DTAB.mkv which will make it open up in 3D which i did
and indeed it does open up in 3D without going into the menu.
