UTF-8 Conversion
Chetwood
What about ANSI conversion ;)
Post by Chetwood » Sun Jun 09, 2013 1:39 pm
Millenium wrote:thanks for your lovely compliments, good to see you being so respectful
Respectful as in high school dropouts talking shit? Ooh, the irony.
Romansh wrote:Converting images to text involves optical character recognition which is a pain in the you-know-what to use.
What is way beyond the scope of this program which is why I don't see this happening anytime soon, no matter what Mike said to keep this guy from going on about it. Which he'll probably do anyway, so I'm out.
Millenium
Re: UTF-8 Conversion
Post by Millenium » Mon Jun 10, 2013 1:54 am
TVD2.0
no manufacturer name
a lot dont have one these days
Romansh
Post by Romansh » Mon Jun 10, 2013 7:52 pm
Millenium wrote:no manufacturer name
Makes it very easy to track down firmware updates :P
Post by Woodstock » Tue Jun 11, 2013 2:52 pm
If it was sold legally in the US, there should at least be an FCC sticker with the registration number. That can be used to track down the manufacturer.
Millenium
Post by Millenium » Fri Jun 14, 2013 7:58 pm
yer makes it real easy and also im not american im australian. i bought it online from china.
Post by Woodstock » Fri Jun 14, 2013 9:14 pm
Ah, so it is unsupported in any way... Are you even sure it handles any text-based subtitle formats properly?
You'll have to use a tool to burn the subtitles into the video, then. Or find a site that has "fan sub" subtitles in one of the text-based formats that your player does support, and merge them into the MKV file with something like MKVToolnix.
Millenium
Post by Millenium » Thu Jun 20, 2013 3:54 am
ofcourse it supports subtitles just like ogs ones
vobsubs work fine if i make a mkv file from a dvd the subs work great
mike said his making a conversion feature eventually to convert blu ray subs to dvd than i'll be set.
Romansh
Post by Romansh » Thu Jun 20, 2013 10:39 am
Millenium wrote:mike said his making a conversion feature eventually to convert blu ray subs to dvd than i'll be set.
Ah, this makes more sense now. PGS -> VobSub conversion is easier and more likely to be easily implemented than PGS -> text.
Millenium
Post by Millenium » Sat Jun 22, 2013 3:00 am
i agree
is there a program that can convert mkv pgs sub files to vobsub that does it without having to redo the entire mkv file again?
so i can just open the mkv file with the software and it converts the subs to vobsub on the fly?
