DEBUG MESSAGE
norbertom8
DEBUG MESSAGE
Post by norbertom8 » Mon Jun 10, 2013 11:30 pm
Hello.
Just trying MakeMKV and followed the tutorial and riped it ok to a MKV file
When I streamed it began to transfer data to VLC very slow..240 kb/s and makemkvco crashed.
Here is the debug message, hope its usefull!!
DEBUG: Code 1 at .PsGa.le7v|^BroyC/:29395103
crowfax
Re: DEBUG MESSAGE
Post by crowfax » Tue Jun 11, 2013 1:37 am
post the whole log.
norbertom8
Re: DEBUG MESSAGE
Post by norbertom8 » Tue Jun 11, 2013 12:23 pm
Hi there.
Where do I find the whole log?
Thanks.
Re: DEBUG MESSAGE
Post by Woodstock » Tue Jun 11, 2013 2:53 pm
The path to the log is printed in the status window when you have debugging turned on. See the link in my signature for more details.
norbertom8
Re: DEBUG MESSAGE
Post by norbertom8 » Wed Jun 12, 2013 9:23 pm
Ok. Just by c?Hnce I found it on my home/user folder. I'll paste it to this post.
Thanks and good luck handling it!!
Debug log started at Tue Jun 11 00:04:45 2013 , written by MakeMKV v1.8.3 linux(x64-release)
001005:0000 MakeMKV v1.8.3 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/nor/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at PKn(h8gFp}AT6'`'.eRs_& :213130122
003028:0000 Title #1 was added (7 cell(s), 0:21:09)
003025:0000 Title #2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=2 pgcn=2 hash=0318C100019F5449
003025:0000 Title #5 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #6 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #7 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #8 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #9 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #10 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=2 pgcn=9 hash=2BB403BB6B92C444
Title skip vts=2 pgcn=10 hash=10482572BFC71168
003025:0000 Title #13 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=2 pgcn=12 hash=6A23E788CBF6991D
003025:0000 Title #15 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #16 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #17 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=2 pgcn=16 hash=AA7307AB791281BC
003025:0000 Title #19 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #21 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #22 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #23 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #24 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #25 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #26 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #27 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #28 was added (2 cell(s), 0:05:32)
003028:0000 Title #29 was added (2 cell(s), 0:05:03)
003028:0000 Title #30 was added (2 cell(s), 0:02:10)
003028:0000 Title #31 was added (2 cell(s), 0:02:18)
003028:0000 Title #32 was added (2 cell(s), 0:12:41)
004500:0000 Streaming server started, web server address is http://192.168.1.132:51000 or http://localhost:51000
004503:0000 UPnP server enabled on address 192.168.1.132
001003:0020 DEBUG: Code 0 at )BQXKMKXv;L>qI5X%1:213134653
Re: DEBUG MESSAGE
Post by mike admin » Sun Jun 16, 2013 7:58 am
The log shows an "impossible" error. Do you see it only with this specific disc or with any disc? What version of VLC are you using?
norbertom8
Re: DEBUG MESSAGE
Post by norbertom8 » Fri Jun 21, 2013 11:12 am
Let me try with another disc and I'll get back to you asap. VLC 2.0.6 I believe.. I'll check that too.
Thanks.
The reader has a Blu-Ray player too and I can't get it to recognize any Blu-Ray disc in Ubuntu or in win 7. With DVDs it works seamlessly under both oss...
