Cannot rip any DVD with MakeMKV
stripeycat
Post by stripeycat » Thu Jun 06, 2013 10:43 am
Trying to begin the process of converting my collection to digital files, but each and every one returns a disc failure.
Below is the detailed Log for the latest attempt at a conversion.
MakeMKV v1.8.3 win(x86-release) started
Debug logging enabled, log will be saved as C:\Documents and Settings\Administrator/MakeMKV_log.txt
Complex multiplex encountered - 28 cells and 12488 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #1 was added (28 cell(s), 1:40:05)
Title #2 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Complex multiplex encountered - 2 cells and 1308 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #3 was added (2 cell(s), 0:10:29)
Complex multiplex encountered - 2 cells and 334 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #4 was added (2 cell(s), 0:02:40)
Complex multiplex encountered - 2 cells and 509 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #5 was added (2 cell(s), 0:04:05)
Saving 1 titles into directory E:/Video/Desperado
DEBUG: Code 1 at .~K.3<}yFzQ-!:121263866
DEBUG: Code 0 at y2j7H7Yd9(~lX'43' :213140196
DEBUG: Code 0 at L#5FAx7`Pr)mT-R(x6a:121263820
DEBUG: Code 0 at NGO$"v5~tz}!xN"=68Je:121262739
DEBUG: Code 0 at q0bcTMe8v)<E]7>1 O::121261681
DEBUG: Code 0 at NGO$"v5~tz}!xN"=68Je:213130743
DEBUG: Code 65 at NGO$"v5~tz}!xN"=68Je:29393332
DEBUG: Code 0 at %t:f(MmAJ6$1Rg0StHYGB:29398645
DEBUG: Code 0 at l^\,NluFOZag\T0$VL<:213132744
DEBUG: Code 0 at l^\,NluFOZag\T0$VL<:121262417
DEBUG: Code 0 at l^\,NluFOZag\T0$VL<:121262210
DEBUG: Code 0 at %t:f(MmAJ6$1Rg0StHYGB:29398369
DEBUG: Code 0 at %t:f(MmAJ6$1Rg0StHYGB:121266925
DEBUG: Code 0 at bC<!oi(fHP6e+5j;vE+:213130697
DEBUG: Code 0 at bC<!oi(fHP6e+5j;vE+:121263958
DEBUG: Code 0 at bC<!oi(fHP6e+5j;vE+:213131801
DEBUG: Code 0 at bC<!oi(fHP6e+5j;vE+:29397564
DEBUG: Code 0 at 9tR-=?.w}{<ow0w_:213130122
DEBUG: Code 0 at v{g_Dq9h@:ramcwS,/:121266580
DEBUG: Code 0 at v{g_Dq9h@:ramcwS,/:29399059
Failed to save title 0 to file E:/Video/Desperado/Desperado_t00.mkv
0 titles saved, 1 failed
Please help.
Re: Cannot rip any DVD with MakeMKV
Post by mike admin » Fri Jun 07, 2013 8:11 am
Are you opening ISO files? What program did you use to make them? Are they encrypted?
stripeycat
Post by stripeycat » Fri Jun 07, 2013 8:21 am
ISO Files? No, i'm just trying to convert my DVD collection to MKV files. None of the DVDs are particularly recent, the newest is over two years old.
I don't know if there is any encryption on each disc. I had thought that MakeMKV would remove encryption were it present.
Post by mike admin » Sat Jun 08, 2013 7:21 am
stripeycat wrote:I had thought that MakeMKV would remove encryption were it present.
It should. But the single log you've posted shows that MakeMKV was unable to find a CSS key, yet the log has no messages about mismatched region. Something is very wrong with your discs or drive.
stripeycat
Post by stripeycat » Sat Jun 08, 2013 11:59 am
It would appear to have been the hardware, unfortunately. I have managed to sneak a copy of MakeMKV onto another machine in the studio, and it is tearing through the same discs without any errors whatsoever.
