Cannot rip any DVD with MakeMKV
stripeycat
Post by stripeycat »
Trying to begin the process of converting my collection to digital files, but each and every one returns a disc failure.
Below is the detailed Log for the latest attempt at a conversion.
MakeMKV v1.8.3 win(x86-release) started
Debug logging enabled, log will be saved as C:\Documents and Settings\Administrator/MakeMKV_log.txt
Complex multiplex encountered - 28 cells and 12488 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #1 was added (28 cell(s), 1:40:05)
Title #2 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Complex multiplex encountered - 2 cells and 1308 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #3 was added (2 cell(s), 0:10:29)
Complex multiplex encountered - 2 cells and 334 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #4 was added (2 cell(s), 0:02:40)
Complex multiplex encountered - 2 cells and 509 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #5 was added (2 cell(s), 0:04:05)
Saving 1 titles into directory E:/Video/Desperado
DEBUG: Code 1 at .~K.3<}yFzQ-!:121263866
DEBUG: Code 0 at y2j7H7Yd9(~lX'43' :213140196
DEBUG: Code 0 at L#5FAx7`Pr)mT-R(x6a:121263820
DEBUG: Code 0 at NGO$"v5~tz}!xN"=68Je:121262739
DEBUG: Code 0 at q0bcTMe8v)<E]7>1 O::121261681
DEBUG: Code 0 at NGO$"v5~tz}!xN"=68Je:213130743
DEBUG: Code 65 at NGO$"v5~tz}!xN"=68Je:29393332
DEBUG: Code 0 at %t:f(MmAJ6$1Rg0StHYGB:29398645
DEBUG: Code 0 at l^\,NluFOZag\T0$VL<:213132744
DEBUG: Code 0 at l^\,NluFOZag\T0$VL<:121262417
DEBUG: Code 0 at l^\,NluFOZag\T0$VL<:121262210
DEBUG: Code 0 at %t:f(MmAJ6$1Rg0StHYGB:29398369
DEBUG: Code 0 at %t:f(MmAJ6$1Rg0StHYGB:121266925
DEBUG: Code 0 at bC<!oi(fHP6e+5j;vE+:213130697
DEBUG: Code 0 at bC<!oi(fHP6e+5j;vE+:121263958
DEBUG: Code 0 at bC<!oi(fHP6e+5j;vE+:213131801
DEBUG: Code 0 at bC<!oi(fHP6e+5j;vE+:29397564
DEBUG: Code 0 at 9tR-=?.w}{<ow0w_:213130122
DEBUG: Code 0 at v{g_Dq9h@:ramcwS,/:121266580
DEBUG: Code 0 at v{g_Dq9h@:ramcwS,/:29399059
Failed to save title 0 to file E:/Video/Desperado/Desperado_t00.mkv
0 titles saved, 1 failed
Please help.
Re: Cannot rip any DVD with MakeMKV
Post by mike admin »
Are you opening ISO files? What program did you use to make them? Are they encrypted?
stripeycat
ISO Files? No, i'm just trying to convert my DVD collection to MKV files. None of the DVDs are particularly recent, the newest is over two years old.
I don't know if there is any encryption on each disc. I had thought that MakeMKV would remove encryption were it present.
stripeycat wrote:I had thought that MakeMKV would remove encryption were it present.
It should. But the single log you've posted shows that MakeMKV was unable to find a CSS key, yet the log has no messages about mismatched region. Something is very wrong with your discs or drive.
stripeycat
It would appear to have been the hardware, unfortunately. I have managed to sneak a copy of MakeMKV onto another machine in the studio, and it is tearing through the same discs without any errors whatsoever.
