Hello all,
I am having trouble with a Blu Ray copy of The Descendants.
This appears to be the correct track but I have tried a complete disc conversion as well.
Title information
Name: The Descendants
Source file name: 00800.mpls
Duration: 1:55:00
Chapters count: 32
Segment count: 1
Segment map: 1
File name: The_Descendants_t02.mkv
My Errors are as follows:
Saving 1 titles into directory /Volumes/Macintosh HD 2
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '675065856'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '675194880'
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, OPERATION IN PROGRESS' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '675459072'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '675459072'
DEBUG: Code 0 at 2|T8*rjX](yuk^<GH/bD:121262739
DEBUG: Code 0 at `2yQ<AeFdwGNKSVn@P.T:121261888
DEBUG: Code 0 at 2|T8*rjX](yuk^<GH/bD:213130743
DEBUG: Code 329814 at 2|T8*rjX](yuk^<GH/bD:29393332
DEBUG: Code 0 at iF?6.!f$+e*Hm1w5BcKL;:121266396
Failed to save title 2 to file /Volumes/Macintosh HD 2/The_Descendants_t02.mkv
0 titles saved, 1 failed
The log file is longer and is attached.
I have MKV 1.8.3 for Mac and an external ASUS BD Drive Model SBW-06D2X-U
I saw a thread from about a year ago were people were having similar issues but their issue was cleared up in 1.7.4.
Any ideas? Thank you so much!
robertpetry
- MakeMKV_log.txt
- (22.37 KiB) Downloaded 529 times
Re: trouble with a Blu Ray copy of The Descendants.
Operating system says the disk is unreadable. This could be dirt or scratches on the disk, or a problem with the drive itself.robertpetry wrote:Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '675065856'
Start by cleaning the disk.
robertpetry
Okay, I'll try that. I looked at it earlier and the disk seemed clean.
I figured there were disk errors built into the copy protection or something.
I'll clean the disk and try again.
robertpetry
No luck.
I guess either the disk is bad or my drive is just too sensitive to small scratches...
setarip_old
Hi!
Return the Blu-ray disc to the place of purchase in exchange for a new one...
