Sony DVDirect Dual Layer Issue for Model VRDMC5
fleck14
Post by fleck14 » Sat May 25, 2013 4:42 pm
Sony DVDirect
Seems to work ok with single layer DVDs but dual layer gives this error:
Calculated BUP offset for VTS #1 does not match one in IFO header.
IFO file for VTS #1 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Title #1 (3:50:41) was skipped due to navigation error
Title #2 (3:50:41) was skipped due to navigation error
It is especially sensitive to dvd burns that go to the end of the media and cutoff.
This happens with overnight burns often.
I am forced to transfer media over 2 single sided disks when over 2 hours in length.
It kinda sucks. LOL I sure hope there is an answer.
Model: VRDMC5
System Info: 5EB5-7240-41R0-B525
(1U0X-0501-0004) 2.1.0.072
Media: Memorex Dual Layer DVD+R 8x 8.5GB 240min
Burner: TSSTCorp CDDVDW SH224BB (Samsung)
OS: Win7 64bit SP-1
8gb ram
i7-3770 3.40 ghz Quad core
MakeMKV_log.txt
Here is by logfile
(2.08 KiB) Downloaded 593 times
fleck14
Re: Sony DVDirect Dual Layer Issue for Model VRDMC5
Post by fleck14 » Thu May 30, 2013 7:51 am
Did I post this in the wrong spot? Is there some other details I can give? Is this a recording device that you are not interested in supporting or are you investigating? Thanks for reading.
Post by Woodstock » Thu May 30, 2013 2:01 pm
While it probably won't help with this, have you tried it with version 1.8.3, which was released last week?
fleck14
Post by fleck14 » Thu May 30, 2013 3:21 pm
Thanks for the reply.
I have not, but the issue is intermittent so it may be recorder related.
I was able to extract 1:47:00 from the disk using mkvmerge. (Loading the VOB)
It resulted in a video that abruptly stops within media player classic.
Windows Media Player seems to load the entire movie but seek does not work.
I think my DVDirect is having issues finalizing the 2nd layer of the disk.
Maybe it is a bug in the firmware. I am checking for updates.
