Sony DVDirect Dual Layer Issue for Model VRDMC5
fleck14
Post by fleck14 »
Sony DVDirect
Seems to work ok with single layer DVDs but dual layer gives this error:
Calculated BUP offset for VTS #1 does not match one in IFO header.
IFO file for VTS #1 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Title #1 (3:50:41) was skipped due to navigation error
Title #2 (3:50:41) was skipped due to navigation error
It is especially sensitive to dvd burns that go to the end of the media and cutoff.
This happens with overnight burns often.
I am forced to transfer media over 2 single sided disks when over 2 hours in length.
It kinda sucks. LOL I sure hope there is an answer.
Model: VRDMC5
System Info: 5EB5-7240-41R0-B525
(1U0X-0501-0004) 2.1.0.072
Media: Memorex Dual Layer DVD+R 8x 8.5GB 240min
Burner: TSSTCorp CDDVDW SH224BB (Samsung)
OS: Win7 64bit SP-1
8gb ram
i7-3770 3.40 ghz Quad core
MakeMKV_log.txt
Here is by logfile
(2.08 KiB) Downloaded 622 times
fleck14
Re: Sony DVDirect Dual Layer Issue for Model VRDMC5
Post by fleck14 »
Did I post this in the wrong spot? Is there some other details I can give? Is this a recording device that you are not interested in supporting or are you investigating? Thanks for reading.
While it probably won't help with this, have you tried it with version 1.8.3, which was released last week?
fleck14
Post by fleck14 »
Thanks for the reply.
I have not, but the issue is intermittent so it may be recorder related.
I was able to extract 1:47:00 from the disk using mkvmerge. (Loading the VOB)
It resulted in a video that abruptly stops within media player classic.
Windows Media Player seems to load the entire movie but seek does not work.
I think my DVDirect is having issues finalizing the 2nd layer of the disk.
Maybe it is a bug in the firmware. I am checking for updates.
