Howto set track name via profile?
I want to automatically set the names for the forced subtitle tracks.
E.g. "English Forced" for English track and "German Forced" for German.
Is there a way (via profile)?
- Contact:
Re: Howto set track name via profile?
Not now, but it was requested a few times, so the feature is in the (big) list.
FattyMoBookyButt
+1
I'm a (relatively) longtime user of MakeMKV, but I just registered for the forums to post this request.
If I could unselect all the titles by default, or only select all titles larger than 3GB...and then have the ability to control the track names in my profile, I'd cut off 98% of my current workflow per disc.
And while I'm at it, if I could edit all the track properties at once, without having to use the drop-down, I'd be super excited and super efficient in my rips.
You can unselect all titles by default using conversion profiles explained in "Changing default track selection".
Pretty sure that only works for tracks, not titles/playlists.Chetwood wrote:You can unselect all titles by default using conversion profiles explained in "Changing default track selection".
With all tracks unselected (-sell:all) no title will be selected, right?
FattyMoBookyButt
This is my current selection rule:Chetwood wrote:With all tracks unselected (-sell:all) no title will be selected, right?
-sel:all,+sel:(favlang|nolang),-sel:(havemulti|havelossless),-sel:mvcvideo,=100:all,-10:favlang,-20:forcedSo it's two extra clicks to 'unselect all' and then to select the title(s) I want, but do it every single time I process a disc. Not a biggie at all, I'd much rather be able to set the track name's in my profile. But I wanted to chime in with a request while I was bumping this one.
You're right. I've just tried "-sel:all" only and while all streams indeed are unchecked, all titles are checked. Maybe Mike'll implement this.
