any thoughts?
thanks
debug file - kung fu panda
- MKB_v8_KUNG_FU_PANDA_AC.tgz
- (13.79 KiB) Downloaded 860 times
Re: debug file - kung fu panda
the correct debug file might help
my guess is a bad disk?
- MakeMKV_log.txt
- (22.44 KiB) Downloaded 824 times
- Contact:
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00004.m2ts' at offset '8894939136'-
Millmaster
Same disk - gest about halfway through and I get this error set:
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00372.m2ts' at offset '13494122496'
Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '\Device\CdRom1' at offset '13494122496'
DEBUG: Code 3221225653 at XLZy#@p!6m/^{4B`f):213131502
Looks more like the drive is disconnecting because not enough power if you ask me is this a USB drive?Millmaster wrote: ↑Fri Nov 10, 2023 7:17 pmSame disk - gest about halfway through and I get this error set:
