Exact Bluray Copy
albertogi
Exact Bluray Copy
Can I get an exact 1:1 bluray copy ripping a bluray that I bought using this program?
Smithcraft
Smithcraft
Re: Exact Bluray Copy
Click on the Backup button.
SC
SC
albertogi
ok, and it is 1:1 exact copy ?
Smithcraft
Yes, it will copy the disc, with either the DRM, or no DRM, as you choose.
SC
SC
albertogi
Sorry but what is drm?
Smithcraft
Digital Rights Management. Or, it's the reason why you just can't copy the contents of the disc to your drive.
SC
SC
albertogi
Oh ok, thanks! And what is the best program to convert mkv to bdm folder?
setarip_old
You can use BD Rebuilder, for one...And what is the best program to convert mkv to bdm folder?
Question.... By "exact copy", are you meaning burn a new BD that is an exact copy of the original?
If so, that is not what MakeMKV is for, and no, it won't do it.
But, if you mean the complete structure of the BD, copied to your hard drive in a form that preserves the resolution of both the audio and video, that's what the "Backup" function is for, and it will create the BD file structure on your hard drive, with optional decryption of the video.
albertogi
Oh ok but if I burn in a BD the complete structure of the BD copied in my hard drive it can be play then in a BD player (PS3)?
http://www.makemkv.com/faq/item/13
Title is "How to burn MKV file to Blu-ray disc for playback in Blu-ray player"
ToxicDreamz
Yes, if you have the proper burning software, you can burn the backed up copy of the Blu-ray to a writable Blu-ray disc and it should play in your PS3 or any other Blu-ray player.
