*TrackAsDefault="false" broken since 1.8.2
jsmith4711
Post by jsmith4711 »
I get always the default flag set for audio and subtitle.
my settings:
<mkvSettings
ignoreForcedSubtitlesFlag="false"
useISO639Type2T="true"
setFirstAudioTrackAsDefault="false"
setFirstSubtitleTrackAsDefault="false"
setFirstForcedSubtitleTrackAsDefault="false"
insertFirstChapter00IfMissing="true"
Is there any setting which i looked over to disable all default flag settings?
John
Re: *TrackAsDefault="false" broken since 1.8.2
Post by mike admin »
Your settings are right. I have to verify this, but if it is the case then the only workaround is to remove default flags in GUI ("MKV Flags" item, "d" stands for default).
animal
Post by animal »
I have run into this problem with the new versions as well. I typically have my "first subtitle track default" setting as "false". The first subtitle track is always set to "default" even though the default profile is set to "false". The only way to change it is by removing the "d" for default in the GUI on the first subtitle track. It does create more work having to constantly remove the flag in the GUI.
Its a bug, introduced with flag editing capabilities in 1.8.2 . Will be fixed in the next version.
