List of DVD/BluRay that haven't worked
microjazz
Star Trek Seasons 1-2 (Haven't tried 3)
#91 Post by microjazz » Thu Jan 21, 2010 5:11 am
Ok there are still problems with the Star Trek Seasons. It simply misses an episode on Discs 2, 3, and 4 (Season 1) and Discs 1, 3, 4, and 7 (Season 2). I don't now what log I should post if it's not seeing the episode to begin with. Should I just tell it to rip everything it sees and post a log? Disc for of season 2 looks like it will work but the end result is a mix of the episode and other special feature. A couple months ago when I first noticed this problem I should note that I used Anydvd. However when I tried disc 7 without anydvd it still wouldn't see an episode.
starburst
Re: List of DVD/BluRay that haven't worked
#92 Post by starburst » Sat Jan 23, 2010 9:26 am
lhilden wrote:Cane Toads: An Unnatural History
MakeMKV wont rip this from the DVD nor will it open a VIDEO_TS.IFO successfully ripped with another application.
MakeMKV v1.4.11 beta win(x86-release) started
Opening files on harddrive at E:/My Documents/DVDFab/FullDisc/DVDVOLUME/VIDEO_TS/
Calculated BUP offset does not match one in IFO header.
Title 1 in VTS 1 is a Multi-PGC title
Title #0 was skipped
Wow, thats a weird one! :(
dtblair
#93 Post by dtblair » Sat Jan 23, 2010 3:25 pm
Any DVD with LPCM track won't work. The LPCM audio has to be unchecked our the make file will fail.
lhilden
#94 Post by lhilden » Sun Jan 24, 2010 12:34 am
Yeah the movie and the error message enjoy the distinction of being both weird and obscure--and possibly even hard to reproduce.
dlorey
#95 Post by dlorey » Sun Jan 24, 2010 7:29 pm
Alan Partridge - Season 1 (UK)
Tried direct from DVD and rip from .ISO.
Tried OS X and Windows versions, both stumble on Title02.
Debug log started at Sun Jan 24 19:24:41 2010 , written by MakeMKV v1.4.11 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.11 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Users\Linzi/MakeMKV_log.txt
003010:000000:0000 Using direct disc access mode
003036:000000:0000 Title #0 was added (7 cell(s), 0:28:55)
003036:000000:0000 Title #1 was added (7 cell(s), 0:29:03)
003036:000000:0000 Title #2 was added (7 cell(s), 0:28:59)
003036:000000:0000 Title #3 was added (7 cell(s), 0:28:56)
003036:000000:0000 Title #4 was added (7 cell(s), 0:28:12)
003036:000000:0000 Title #5 was added (7 cell(s), 0:28:46)
003016:000000:0000 Title 1 in VTS 7 is a Multi-PGC title
003015:000000:0000 Title #6 was skipped
003016:000000:0000 Title 1 in VTS 8 is a Multi-PGC title
003015:000000:0000 Title #7 was skipped
003020:000000:0000 Title #8 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #9 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory C:/Users/Linzi/Desktop
002013:000000:0020 Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
001011:000000:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
005003:000000:0000 Failed to save title 2 to file C:/Users/Linzi/Desktop/title02.mkv
005004:000000:0000 0 titles saved, 1 failed
005037:000000:0204 Copy complete. 0 titles saved, 1 failed.
Application exited at Sun Jan 24 19:26:51 2010
makeitgo
#96 Post by makeitgo » Sun Jan 24, 2010 9:32 pm
Is there a list of movies this program will actually work with? It seems that over half my isos stored from physical discs (I've even tried going from the originals or re-ripping the isos) don't work. Main titles just fail and tv series are buggy at best. It seems like an issue having to do with either copy protection or how it reads menus. When I use DVDFab to recreate a new image without the menus or protection, it's magically able to work again in MakeMKV, but this is suboptimal. There's no way that I can use DVDfab to re-encode isos for my dvd collection before using makemkv. Would take far too much time to do all of them(especially when I spent the time to iso them in the first place). Any fix for this in the works?
setarip_old
#97 Post by setarip_old » Sun Jan 24, 2010 9:43 pm
Hi!
I have successfully used MakeMKV to rip more than two hundred DVDs and nearly as many BluRay discs.
1) What software and procedures did you use to rip your original DVDs?
2) Have you played the .ISOs to make sure they aren't problematic?
makeitgo
#98 Post by makeitgo » Sun Jan 24, 2010 11:35 pm
They were ripped with either DVDFab Platinum or AnyDVD HD, always ripped to iso. isos play fine in any dvd/video software I run them through. The exact settings, I'm not 100% sure on. if it was AnyDVD there aren't that many settings. For DVDFab, I either used "clone" method or "Full Disc" methods. As far as I can tell that doesn't seem to have made a difference whether or not the disc is readable in MakeMKV though (some are most aren't). All of the isos are fully functional isos though. Is there a more stable release I should be using.
I'm running Windows 7x32 if that makes any difference.
setarip_old
#99 Post by setarip_old » Mon Jan 25, 2010 1:08 am
@makeitgo
This would be indicative of a problem with the ORIGINAL .ISO... (Also, MakeMKV does nothing with menus)
As an experiment, try the following:
1) Use ONLY MakeMKV (turn
COMPLETELY OFF AnyDVD) to rip the main movie from an ORIGINAL DVD. Does it successfully create a properly functioning MKV?
2) Use your favorite decrypting program to rip that same ORIGINAL DVD to your hard drive - and then use IMGBurn to create an .ISO image file. WITHOUT mounting the .ISO image, use ONLY MakeMKV (turn
COMPLETELY OFF AnyDVD) to rip the main movie from the .ISO image. Does it successfully create a properly functioning MKV?
3) If not, try mounting the .ISO image with Virtual Clone Drive. Use ONLY MakeMKV (turn
makeitgo
#100 Post by makeitgo » Mon Jan 25, 2010 5:54 am
1) Will try this and post back
2) Totally defeats the purpose of using MakeMKV in the first place. MKVmerge will take the uncompressed DVD Shrink vobs and put them in a clean mkv file without the extra step of recreating isos.
3) I was already doing this with Daemon Tools. Virtual Clone Drive instead helped on a couple discs, but not the majority.
setarip_old
#101 Post by setarip_old » Mon Jan 25, 2010 7:10 pm
@makeitgo
As I said, the three procedures are each part of an EXPERIMENT to try to track down the cause(s) of your problem...
makeitgo
#102 Post by makeitgo » Mon Jan 25, 2010 11:54 pm
I have AnyDVD enabled since it didn't seem to make any difference one way or another. I've now tested the original DVD's from some of the isos that weren't converting. So far all work fine, so I'll have to play with the iso settings in DVDFab/AnyDVD when ripping to see what doesn't seem to agree with MakeMKV.
I did notice one thing mildly frustrating... it seems like the subtitles it made from the original iso were all transparent and very hard to see. Is there any way around this or is it just taking the direct subtitle images and offloading them into a file in the mkv container?
setarip_old
#103 Post by setarip_old » Tue Jan 26, 2010 12:03 am
@makeitgo
Glad to hear we've got you on the right track now ;>}
It appears that you still donh't understand the basic tenet of SUCCESSFUL EXPERIMENTATION - ALL OTHER THINGS REMAINING EQUAL.
I provided you with three specific test procedures, including specific programs to use or not use.
For your sake, please follow my suggestions "to the letter" - including having AnyDVD completely turned off while performing these procedures and use IMGBurn to create the .ISO image files...
makeitgo
#104 Post by makeitgo » Tue Jan 26, 2010 11:44 pm
Title #0 has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cell 13 was discarded (structure protection?)
Title #1 was added (12 cell(s), 1:48:31)
Cell 4 was discarded (structure protection?)
Title #2 was added (3 cell(s), 0:07:09)
Title #3 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cell 2 was discarded (structure protection?)
Title #6 was added (1 cell(s), 0:11:48)
Cell 36 was discarded (structure protection?)
Title #0 was added (35 cell(s), 1:48:34)
Title 6 in VTS 1 is a Multi-PGC title
Title #1 was skipped
Title #2 was added (1 cell(s), 0:02:21)
Title #3 has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 was added (1 cell(s), 0:02:30)
Title #12 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory D:/MakeMKV
DEBUG: Code 669 at ~SPsW}`Kb BS'`Lj=(U.&:213131985
DEBUG: Code 672 at ~SPsW}`Kb BS'`Lj=(U.&:29395080
DEBUG: Code 1571 at ~SPsW}`Kb BS'`Lj=(U.&:29394804
DEBUG: Code 49 at DwB~,F^f>Kh;R390uWU:121265706
DEBUG: Code 0 at ~SPsW}`Kb BS'`Lj=(U.&:121264671
DEBUG: Code 0 at %q.BKdO'G3#{@2tV,{D:213132951
Failed to save title 0 to file D:/MakeMKV/title00.mkv
Ok, here's my error output. BTW, MakeMKV is the only program having issues with my isos so regardless of the "right" method of making them, MakeMKV has iso compatibility issues. I haven't been able to get IMGburn to work right, so if that's what you use to rip DVD's tell me your settings so I can try them. Any idea when there's going to be a usable stable release?
setarip_old
#105 Post by setarip_old » Wed Jan 27, 2010 12:12 am
@makeitgo
1) IMGBurn isn't a ripping program
2) Go to the IMGBurn website for detailed information (if needed) to use it properly
3)
There is nothing incomplete or "unstable" about either MakeMKV or IMGBurn. MakeMKV is referred to as being in beta because NEW functions are still being/to be added. Your presumption of MakeMKV being at fault is unjustified.
In light of the fact that MakeMKV has been used by many different users to successfully create MKVs from properly created .ISOs, I'd suggest that the problem is yours, either regarding your methodology or your system. If you can successfully complete the three scenarios I provided, I'm fairly certain you'll see your problems disappear ;>}
