Apparently there's an updated AACS
MakeMKV v1.8.3 win(x64-release) started
Loaded 4 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as C:\Users/.MakeMKV/dump_A_Good_Day_to_Die_Hard_E1705C7E75B03A2E.tgz
BD+ code processed but no FUTs were obtained, errors may follow
After backing up, the blu ray is garbled and unwatchable. Thanks for any help.
Good Day to Die Hard (2013)
setarip_old
Re: Good Day to Die Hard (2013)
@Romansh
Hi!
Would you please be good enought to explain your post? Thank you ;>}
Hi!
He means that BD+ is not the same thing as AACS encryption. There is a link in the MakeMKV FAQ section to an explanation of what BD+ is.
Send that file to Mike at svq@makemkv.com and he can use it to generate a fix-up code for it.Saved BD+ dump file as C:\Users/.MakeMKV/dump_A_Good_Day_to_Die_Hard_E1705C7E75B03A2E.tgz
Romansh
Maybe tomorrow. But Woodstock beat me to it.setarip_old wrote:@Romansh
Hi!
MickeyRooney777
Thanks guys. I already used AnyDVD to decrypt and MakeMKV to do the rest. I didn't save the file. Sorry about not knowing the proper encryption terminology.
Did you go and delete the BD+ file dump? MakeMKV saved it as part of its normal operations, so it would still be present unless you removed it.
The link I was forgetting is this one: http://www.makemkv.com/svq/
It describes how MakeMKV deals with BD+ fix-up code.
