The Last Stand (2013)
stephenkingrules
Re: The Last Stand (2013)
#16 Post by stephenkingrules » Thu May 23, 2013 3:23 am
Thanks for all the help guys, but my numbers don't match those for 1:47:13. I've got:
00038
00280
00386
00474
00797
I'll try to figure out these numbers if anyone else has them...
Correction: I've deduced that my correct list is 00797, for a Region A copy in Canada.
Last edited by stephenkingrules on Fri May 24, 2013 5:04 am, edited 1 time in total.
Smithcraft
#17 Post by Smithcraft » Thu May 23, 2013 11:02 am
You should also list what region your disc is from, and if it's maybe a collectors/steelbook/regular edition.
SC
eNoize
#18 Post by eNoize » Thu May 23, 2013 10:13 pm
my copy is a Region A single disc with UltraViolet Digital Copy
dashocker
#19 Post by dashocker » Fri May 24, 2013 5:42 am
cjsiv wrote:603 works. (1:47:13) 16 chapters
I hope this is correct :)
ArieS
#20 Post by ArieS » Fri May 24, 2013 6:18 pm
Yes, it is correct.
#21 Post by mike admin » Sat May 25, 2013 5:58 am
This madness certainly will be dealt with. For now, the "easiest" manual path:
1. insert the disc in player, play main movie. If your player displays playlist id, then you're done. If not continue.
2. Take a pencil and a piece of paper, chose two or 3 chapters/episodes (for example No 3, No 8, No 15). On player navigate to these chapter and write down exact chapter time (all players display the current running time one way or another).
3. In MakeMKV go through each title one by one, expand "chapters" entry and compare times. Usually a timestamp for two arbitrary chapters is enough to filter out all fakes.
MickeyRooney777
#22 Post by MickeyRooney777 » Thu May 30, 2013 5:55 pm
Something strange. When I load this into VLC it plays a track of 1:50:07 which corresponds to playlist 465. All chapters match up except this has 17. Is this an extended version?
amarshonarbangla
#23 Post by amarshonarbangla » Fri Jun 14, 2013 6:13 pm
Sorry to bump up an old thread. I wanted to add that that DVDFab is reporting 603 as the correct playlist. DVDFab shows that 603 has 17 chapters, but MakeMKV is showing it has 16. Anyone knows why that is?
setarip_old
#24 Post by setarip_old » Sun Jun 16, 2013 10:57 pm
DVDFab probably starts with Chapter "0", while MakeMKV probably starts with Chapter "1"...
adamf154
#25 Post by adamf154 » Sun Jul 07, 2013 1:06 pm
Jon Walker wrote:
eNoize wrote:Ok, so for anyone that doesn't have a 603 on their disc, these are the options which worked for me without issue, all of them with a runtime of 1:47:13 and 16 Chapters:
00001.mpls
00043.mpls
00276.mpls
00842.mpls
00941.mpls
Hope that helps.
842 appears to contain the correct segment order on my disc.
I have these chapters aswell, how did you manage to filter out the fake ones to get to the right on and how did you know it was 842, that was correct, they all look the same to me.
geogan
#26 Post by geogan » Wed Nov 13, 2013 10:30 pm
On my disc the numbers are different again (Europe region disc) Only two have length 1:47:13
00035.mpls
Duration: 1:47:13
Chapters count: 16
Segment count: 16
Segment map: 508,501,504,519,503,517,507,512,513,510,516,509,520,502,511,506
00739.mpls
Duration: 1:47:13
Chapters count: 16
Segment count: 15
Segment map: 508,501,505,519,503,515,512,518,510,509,514,520,502,511,506
Just checked AnyDVD. Says it's 739...
p.s. "If your player displays playlist id, then you're done. If not continue" ... which PC bluray player displays the id? Not Cyberlink anyway.
"In MakeMKV go through each title one by one, expand "chapters" entry and compare times" - where is this chapter stuff??? I don't see any chapter expansion in the titles??
p.p.s. VLC player must be picking the WRONG playlist (duration 1:48:15) because it starts the film (after the Lionsgate logo) with Arnie walking into the parade (skips the night scene before this with police car)
dannyboy48888
#27 Post by dannyboy48888 » Mon Dec 23, 2013 6:46 am
Hello folks,
@Mike_Admin: as simple as your solution is there is one problem...us Linux folks don't have a lisenced player to verifiy this on. After trail and error 506 (Title 40) worked. Any update on a easier way?
