Program crashes
lei013
Program crashes
Post by lei013 »
Hi, I'm only using the trial version. I just started using this program so I'm not too familiar with it but I have backed up a few other BDs to my hard drive successfully with MakeMKV.
When I try to rip this blu-ray, the process starts and then a few seconds later I get a Windows error saying the program crashed.
The disc is brand new and it's a 3D blu-ray. I don't know if the 3D is the cause. But thanks if you can help.
Windows error:
Problem signature:
  Problem Event Name:	APPCRASH
  Application Name:	makemkvcon64.exe
  Application Version:	1.8.0.0
  Application Timestamp:	5125c10d
  Fault Module Name:	makemkvcon64.exe
  Fault Module Version:	1.8.0.0
  Fault Module Timestamp:	5125c10d
  Exception Code:	c0000005
  Exception Offset:	00000000001b96c8
  OS Version:	6.1.7601.2.1.0.768.3
  Locale ID:	1033
  Additional Information 1:	f953
  Additional Information 2:	f9535fe31e473ad2a123047ccad4c308
  Additional Information 3:	8605
  Additional Information 4:	8605f58e22f2f3f291cb350fa9ce3d84
MakeMKV log:
Debug log started at Fri Mar 22 23:56:39 2013 , written by MakeMKV v1.8.0 win(x64-release)
001005:0000 MakeMKV v1.8.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Lei/MakeMKV_log.txt
005072:0000 Backing up disc into folder "M:/Video/backup/2012_INFINITE_CONCERT_3D_MOVIE"
DAFD=ZeNpjYGDgYWBgcGDk5WSRZ2RiZEADAAzNAIs=
DCE=vcQ3yOP2LdC7YRWkQFBlshEPAb7y12Uo4s3JzqgHAdk94rIqOMT7u1z0jiFG7kCVtEuZKY4q+WX0kX8672QMkyvKjekeh1Aan668MPTURbUsyLis7HIHC3BvgR0KIBk4HpCU8khwgqxCnJm/MI5yK/aTLRzLm2RBxg==
DCE=e+6lhFwX7LP0K6xAr0/CWvlsceU3rfHUkR3gAS5/J/AneCTvbuX7RHXQ7KOBzvs2X//v18NiPlmLNSNDGIIsjafM3vlXjWbnmGA5Xs6R/IBulFUOY1inW8IzL5qW4fp/LLFH3syXwT1Cm06PnT1v2t04cHehSfd5Uw==
Re: Program crashes
Post by mike admin »
That's unfortunate. I have to ask you for the full dump - /onlinehelp/dump.html
user114
Re: Program crashes
Post by user114 »
same issue here.
program crashes when starts to make the backup.
here my dumps:
[links to private information removed]
Re: Program crashes
Thanks a lot for submitting the dump. Fixed in 1.8.3.
