The Last Stand (2013)
BD disc comes up with several ripping options, each showing different time lengths for the same movie.
Experimenting with two possible mpls options at the moment. Either 460 or 506 should be the correct one.
Re: The Last Stand (2013)
603 seems to be the correct one. Just ripped it and I haven't watched beginning to end yet, but everything seems to be right. Please correct if I'm wrong.
Can anyone else confirm if it is 603? There are a ton of options to choose from.
I've tried five different files now, and none are correct. I hope someone else has better luck.
did you try 603?eNoize wrote:I've tried five different files now, and none are correct. I hope someone else has better luck.
Has anyone confirmed that 603 is the right one? If so, I don't have an mlps 603 on my disc, could someone tell me the exact duration (hours:minutes:seconds) of their 603 so I can cross reference and match them to my disc? Thanks!
603 is 1:47:13 with 15 chapters
I don't have a 603 on my disc either, and the only sections that clock in at 1:47:13 come with 16 chapters, not 15. ![Evil or Very Mad :evil:](./images/smilies/icon_evil.gif)
I have a 603 (1:47:13) and it has 16 chapters, not 15...
603 works. (1:47:13) 16 chapters
Thanks imgodlike, I'll try that out and keep everyone posted.
Are we sure 603 (or anything equivalent) is the correct one? Please verify that at the 00:03:33 mark (or somewhere close to that), the following screen doesn't suddenly pop up
![Image](http://s19.postimg.org/k0gp142cv/last_stand.jpg)
because in almost every option I've tried, four minutes into the movie is interrupted either by that screen or a scene completely out of sequence.
Ok, so for anyone that doesn't have a 603 on their disc, these are the options which worked for me without issue, all of them with a runtime of 1:47:13 and 16 Chapters:
00001.mpls
00043.mpls
00276.mpls
00842.mpls
00941.mpls
Hope that helps.
00001.mpls
00043.mpls
00276.mpls
00842.mpls
00941.mpls
Hope that helps.
842 appears to contain the correct segment order on my disc.eNoize wrote:Ok, so for anyone that doesn't have a 603 on their disc, these are the options which worked for me without issue, all of them with a runtime of 1:47:13 and 16 Chapters:
00001.mpls
00043.mpls
00276.mpls
00842.mpls
00941.mpls
Hope that helps.
![Image](http://downloads.walker4.me/downloads/Temporary_files/small_white_chi.gif)
