Razor / The plan (Battlestar Galactica)
Zibri
Post by Zibri »
Razor: (iso obtained using dd on linux)
MakeMKV v1.8.2 win(x64-release) started
DEBUG: Code 3221225489 at +s"`*n5Lxoy{JV:&,c:29396575
DEBUG: Code 3221225489 at +s"`*n5Lxoy{JV:&,c:29393930
Error 'OS error - The end-of-file marker has been reached. There is no valid data in the file beyond this marker' occurred while reading '/BDMV/META/DL/bdmt_eng.xml' at offset '0'
DEBUG: Code 0 at )J<,J#6CNGP+0:29394298
DEBUG: Code 0 at ,H:q8sk#+eKlB=I$|:29394873
DEBUG: Code 0 at &F[dW6qK.-?)T3sV:121263544
DEBUG: Code 0 at &F[dW6qK.-?)T3sV:121265223
The Plan (iso obtained using dd on linux)
P.S.
The beta key expires in a week :(
Re: Razor / The plan (Battlestar Galactica)
There is no reason to rip to ISO before using MakeMKV. Not to mention the fact that dd doesn't give you a true ISO from a video disk, due to the copy protection.
What happens when you run MakeMKV against the disk itself?
And version 1.8.3 just came out, so you can install that and update the key through the end of June (at least).
Post by mike admin »
/faq/item/12/catid/8
