The Last Stand (2013)
eNoize
#1 Post by eNoize » Tue May 21, 2013 10:13 pm
BD disc comes up with several ripping options, each showing different time lengths for the same movie.
Experimenting with two possible mpls options at the moment. Either 460 or 506 should be the correct one.
cjsiv
Re: The Last Stand (2013)
#2 Post by cjsiv » Tue May 21, 2013 10:59 pm
603 seems to be the correct one. Just ripped it and I haven't watched beginning to end yet, but everything seems to be right. Please correct if I'm wrong.
imgodlike
#3 Post by imgodlike » Tue May 21, 2013 11:59 pm
Can anyone else confirm if it is 603? There are a ton of options to choose from.
eNoize
#4 Post by eNoize » Wed May 22, 2013 12:18 am
Damn, neither 460 or 506 is correct. In fact, one of them (460, I believe it was) is interrupted early on by the following image before returning to the movie. Image
Even weirder is the fact that my copy doesn't even show an option for 603 mpls. Closest I have is 601, which I'm trying next.
eNoize
#5 Post by eNoize » Wed May 22, 2013 2:14 am
I've tried five different files now, and none are correct. I hope someone else has better luck.
imgodlike
#6 Post by imgodlike » Wed May 22, 2013 2:39 am
eNoize wrote:I've tried five different files now, and none are correct. I hope someone else has better luck.
did you try 603?
stephenkingrules
#7 Post by stephenkingrules » Wed May 22, 2013 5:06 am
Has anyone confirmed that 603 is the right one? If so, I don't have an mlps 603 on my disc, could someone tell me the exact duration (hours:minutes:seconds) of their 603 so I can cross reference and match them to my disc? Thanks!
imgodlike
#8 Post by imgodlike » Wed May 22, 2013 5:22 am
603 is 1:47:13 with 15 chapters
eNoize
#9 Post by eNoize » Wed May 22, 2013 5:56 am
I don't have a 603 on my disc either, and the only sections that clock in at 1:47:13 come with 16 chapters, not 15. :evil:
ArieS
#10 Post by ArieS » Wed May 22, 2013 8:56 am
I have a 603 (1:47:13) and it has 16 chapters, not 15...
cjsiv
#11 Post by cjsiv » Wed May 22, 2013 12:50 pm
603 works. (1:47:13) 16 chapters
stephenkingrules
#12 Post by stephenkingrules » Wed May 22, 2013 2:39 pm
Thanks imgodlike, I'll try that out and keep everyone posted.
eNoize
#13 Post by eNoize » Wed May 22, 2013 6:16 pm
Are we sure 603 (or anything equivalent) is the correct one? Please verify that at the 00:03:33 mark (or somewhere close to that), the following screen doesn't suddenly pop up
because in almost every option I've tried, four minutes into the movie is interrupted either by that screen or a scene completely out of sequence.
eNoize
#14 Post by eNoize » Wed May 22, 2013 11:14 pm
Ok, so for anyone that doesn't have a 603 on their disc, these are the options which worked for me without issue, all of them with a runtime of 1:47:13 and 16 Chapters:
00001.mpls
00043.mpls
00276.mpls
00842.mpls
00941.mpls
Hope that helps.
Jon Walker
#15 Post by Jon Walker » Thu May 23, 2013 1:06 am
eNoize wrote:Ok, so for anyone that doesn't have a 603 on their disc, these are the options which worked for me without issue, all of them with a runtime of 1:47:13 and 16 Chapters:
00001.mpls
00043.mpls
00276.mpls
00842.mpls
00941.mpls
Hope that helps.
842 appears to contain the correct segment order on my disc.
