Cannot open Blu Rays
classicj
#1 Post by classicj » Mon May 20, 2013 5:28 pm
Been having no luck getting makemkv to open any Blu Rays on my machine. Ive been able to rip dvds okay though. I thought it was the drive at first but im able to rip blu ray from other programs like DVDFab. Makemkv will not open any blu ray new or old. Disk are clean, practically new.
Drive im using is like generic BD-ROM from Amazon.
Manufacturer is BLU RAY (as stated from Amazon). But when you open up in MakeMKV it says its HP.
Been getting this error every time i open BD.
Error 'Scsi error - ILLEGAL REQUEST:SYSTEM RESOURCE FAILURE' occurred while issuing SCSI command A40..002000800 to device 'DASPI:IODASPIService:47fc1d16b74a7d73:'
DEBUG: Code 0 at Z%Sf%sG}{a{!(%#12f:121262394
DEBUG: Code 1 at Z%Sf%sG}{a{!(%#12f:121262394
DEBUG: Code 2 at Z%Sf%sG}{a{!(%#12f:121262394
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'DASPI:IODASPIService:47fc1d16b74a7d73:'
DEBUG: Code 0 at Z%Sf%sG}{a{!(%#12f:121264303
DEBUG: Code 4 at Z%Sf%sG}{a{!(%#12f:121262394
DEBUG: Code 0 at (^[b[i@E)@h)Mx5^(:121262509
DEBUG: Code 0 at MTUeuJ"<+Oj9Lz[V:121263544
DEBUG: Code 0 at MTUeuJ"<+Oj9Lz[V:121265223
Any help would be great.
Re: Cannot open Blu Rays
#2 Post by Woodstock » Mon May 20, 2013 8:40 pm
You stripped out the portion of the log that said what version of MakeMKV you are running. If it isn't at least 1.7.9 (1.8.2 is current), you will get those errors if you recently inserted a BD with the latest AACS on it. The drive will refuse to talk to prior versions of MakeMKV, because the keys from earlier versions were revoked.
classicj
#3 Post by classicj » Mon May 20, 2013 10:00 pm
Sorry bout that. Im running the latest version.
Here's the first few lines -
MakeMKV v1.8.2 darwin(x86-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Optical drive "BD-ROM hp BDDVDRW CT10L YC09" opened in DASPI v1.3 mode.
Evaluation version, 25 day(s) out of 30 remaining
#4 Post by mike admin » Wed May 22, 2013 9:10 am
What is the "latest AACS version" shown on MakeMKV main screen? Please try the latest version, 1.8.3 - it has update for v40.
classicj
#5 Post by classicj » Thu May 23, 2013 12:59 am
Tried the v1.8.3 and same results still wont open the BD.
Under drive information - latest AACS version is 30. But Ive tried ripping movies with AACS v3 (Last Samurai) and same result.
Could it be the drive Im using? Seems like everyone can at least "open" 1 movie. Im 0 for 20 right now with about 80 movies to go.
classicj
#6 Post by classicj » Sun May 26, 2013 4:30 am
So no info on the error codes im generating?
#7 Post by mike admin » Tue May 28, 2013 5:04 am
This is certainly an error with your drive. Is it a regular drive (not pulled from the hardware player)? Were you able to use any other software to play/copy blu-rays with this drive?
