Howto set track name via profile?
tommce
#1 Post by tommce » Mon May 20, 2013 3:08 pm
I want to automatically set the names for the forced subtitle tracks.
E.g. "English Forced" for English track and "German Forced" for German.
Is there a way (via profile)?
Re: Howto set track name via profile?
#2 Post by mike admin » Wed May 29, 2013 9:08 am
Not now, but it was requested a few times, so the feature is in the (big) list.
FattyMoBookyButt
#3 Post by FattyMoBookyButt » Sat Jun 15, 2013 4:38 pm
+1
I'm a (relatively) longtime user of MakeMKV, but I just registered for the forums to post this request.
If I could unselect all the titles by default, or only select all titles larger than 3GB...and then have the ability to control the track names in my profile, I'd cut off 98% of my current workflow per disc.
And while I'm at it, if I could edit all the track properties at once, without having to use the drop-down, I'd be super excited and super efficient in my rips.
Chetwood
#4 Post by Chetwood » Sun Jun 16, 2013 4:46 am
You can unselect all titles by default using conversion profiles explained in "Changing default track selection".
Romansh
#5 Post by Romansh » Sun Jun 16, 2013 3:47 pm
Chetwood wrote:You can unselect all titles by default using conversion profiles explained in "Changing default track selection".
Pretty sure that only works for tracks, not titles/playlists.
Chetwood
#6 Post by Chetwood » Mon Jun 17, 2013 5:06 am
With all tracks unselected (-sell:all) no title will be selected, right?
FattyMoBookyButt
#7 Post by FattyMoBookyButt » Mon Jun 17, 2013 4:49 pm
Chetwood wrote:With all tracks unselected (-sell:all) no title will be selected, right?
This is my current selection rule:
-sel:all,+sel:(favlang|nolang),-sel:(havemulti|havelossless),-sel:mvcvideo,=100:all,-10:favlang,-20:forced
And it selects all the titles.
So it's two extra clicks to 'unselect all' and then to select the title(s) I want, but do it every single time I process a disc. Not a biggie at all, I'd much rather be able to set the track name's in my profile. But I wanted to chime in with a request while I was bumping this one.
Chetwood
#8 Post by Chetwood » Tue Jun 18, 2013 10:10 am
You're right. I've just tried "-sel:all" only and while all streams indeed are unchecked, all titles are checked. Maybe Mike'll implement this.
