[Solved] Output folder is reset upon each DVD analyze
AlexanderM
Post by AlexanderM »
Using MakeMKV Beta 1.8.2. Win7 x64.
Every time I've opened a DVD (aka. analyzing it), the "Output folder" is reset to E:/Video/XXX where XXX is the title of the DVD. I assume it defaults to the E: drive since I have my "MakeMKV data directory" (under Options, General tab) set to a subdirectory on my E: drive, but this directory is apparently ignored and not used for anything?
It would be really nice if this output folder could either be set in the options, or was just saved from rip to rip.
Re: [Bug] Output folder is reset upon each DVD analyze
I would guess you have the "Default destination" set to "SemiAuto" in the Video tab, which will append the DVD title to the directory you have listed. There ARE 3 other settings you can play with.... ;)
AlexanderM
Ah, terrible sorry for missing that option on the very first page. :oops:
