Hey guys, new to the forum - I've run into a problem ripping my Close Encounters Blu Ray disc. It initially failed on OSX Mountain Lion and typically if a disc failed here I'd have better results in Windows. This time I had no luck with either OS.
The process gets to the end and I get these errors:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00025.m2ts' at offset '0'
Then I get a "Copy complete. 1 titles saved, 1 failed" message. Turns out I only got 347MB file saved and nothing else.
Am I missing something or is there something I can do to correct this issue?
Thanks.
Rip Fail - Close Encounteres of the Third Kind
hedcase
crowfax
Re: Rip Fail - Close Encounteres of the Third Kind
You can try cleaning your disc, or swapping it for a new one. Your drive can't read it.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
hedcase
It's a new, clean disc that plays fine in my Samsung standalone unit. Maybe I should be looking at a different external drive for my computer?
Or make sure that the drive is getting fully powered. There are a lot of reports of USB bus-powered drives failing rips because there is insufficient power available on the USB bus to run them at full speed. Using a powered hub "fixes" the issue, although some drives fix it by having TWO USB plugs on their cable, to get enough power.
hedcase
This ASUS is new and has external power. I'll poke around and see what else is out there. Does anyone recommend anything solid?
Smithcraft
Just because your disc player can play it, doesn't mean it's not a faulty disc.
SC
SC
hedcase
True, but this has happened with a couple other discs so I figured it was the drive.
