Rip Fail - Close Encounteres of the Third Kind
hedcase
Post by hedcase »
Hey guys, new to the forum - I've run into a problem ripping my Close Encounters Blu Ray disc. It initially failed on OSX Mountain Lion and typically if a disc failed here I'd have better results in Windows. This time I had no luck with either OS.
The process gets to the end and I get these errors:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00025.m2ts' at offset '0'
Then I get a "Copy complete. 1 titles saved, 1 failed" message. Turns out I only got 347MB file saved and nothing else.
Am I missing something or is there something I can do to correct this issue?
Thanks.
crowfax
Re: Rip Fail - Close Encounteres of the Third Kind
Post by crowfax »
You can try cleaning your disc, or swapping it for a new one. Your drive can't read it.
hedcase
Post by hedcase »
It's a new, clean disc that plays fine in my Samsung standalone unit. Maybe I should be looking at a different external drive for my computer?
Or make sure that the drive is getting fully powered. There are a lot of reports of USB bus-powered drives failing rips because there is insufficient power available on the USB bus to run them at full speed. Using a powered hub "fixes" the issue, although some drives fix it by having TWO USB plugs on their cable, to get enough power.
hedcase
Post by hedcase »
This ASUS is new and has external power. I'll poke around and see what else is out there. Does anyone recommend anything solid?
Smithcraft
Post by Smithcraft »
Just because your disc player can play it, doesn't mean it's not a faulty disc.
SC
hedcase
Post by hedcase »
True, but this has happened with a couple other discs so I figured it was the drive.
