Program does not recognized the bluray drive
albertogi
#1 Post by albertogi » Wed May 15, 2013 5:16 pm
Hi guys, I just download the software and I have various questions:
- Can I decrypt bluray movies without internet connection?
- I have an acer 5517 with dvd rom. I have an external bluray burner Pioneer BD-RW BDR-TD03 connected and power by usb. The program does not recognized the burner for decryption, only the internal dvd-rom that came with acer. How can I decrypt a bluray? Any help? Thanks!!!
Smithcraft
Re: Program does not recognized the bluray drive
#2 Post by Smithcraft » Wed May 15, 2013 8:15 pm
One thread works better.
However, you might want to get more power for the drive, as there are some threads here about a Samsung USB drive that had issues ripping while only being bus powered.
SC
setarip_old
#3 Post by setarip_old » Thu May 16, 2013 12:42 am
@albertogi
Hi!
You may have to install a "UDF 2.50" driver (Although I believe Makemkv takes care of that invisibly)...
#4 Post by mike admin » Fri May 17, 2013 8:45 am
By all means, do NOT install UDF driver. You are likely only to get additional problems without any benefits.
setarip_old
#5 Post by setarip_old » Sat May 18, 2013 6:35 pm
BY ALL MEANS, if "mike admin" says "DON'T INSTALL THE UDF 2.50 DRIVER" then DON'T install it.
He's the author and he certainly knows best!!!
albertogi
#6 Post by albertogi » Mon May 20, 2013 7:00 pm
Suddenly it recognized the drive, thanks!! I want to backup my movies in Bluray discs but the mayority of them are above 25gb.
- How I split from mkv to two BMDV folders for backup my bluray movies?
- How I compress 30gb from mkv to BDMV to one bluraydisc?
#7 Post by Woodstock » Mon May 20, 2013 8:44 pm
You would have to re-author the disks using a BD authoring program, OR go with dual-layer BD disks, which will hold up to 50GB.
By re-authoring, you can remove things you don't want, like extras, unwanted audio/subtitle tracks, etc. If the main title is over 25GB, though, dual-layer is the only way you can do it and still have the result playable in a BD player.
setarip_old
#8 Post by setarip_old » Mon May 20, 2013 9:09 pm
What did you do or alter that now allowed it to recognize your Blu-ray drive?
albertogi
#9 Post by albertogi » Mon May 20, 2013 11:16 pm
So compress files can not be play in a bd player (ps3)?
I load avatar 3d and appears two files of 49gb. One with only one chapter and the other one with all the chapters. Both 49gb. I have to convert both to mkv for playback in bluray player?
B
regarding the driver, suddenly recognized it. I did not do anything.
