Is there a way to have MakeMKV auto select....
CapWKidd
Post by CapWKidd »
Is there a way to have MakeMKV auto select uncompressed audio formats?
Smithcraft
Re: Is there a way to have MakeMKV auto select....
Post by Smithcraft »
I would imagine you could create a profile that favors the lossless/uncompressed audio streams.
http://www.makemkv.com/forum2/viewforum.php?f=10
SC
CapWKidd
Post by CapWKidd »
Great, thanks! Took me a few minutes to figure out the syntax, but figured out adding "+sel:lossless" to the end of the string worked, I guess I could remove the -sel:(havemulti|havecore) to get the same end result, eh?
