Problems Ripping Gangster Squad . . .
mrtuneup2
Post by mrtuneup2 » Sun May 12, 2013 7:28 pm
It seem to do fine until the end. Any suggestions?
Saving 1 titles into directory /Users/mrtuneup2/Movies/Gangster_Squad
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '15669325824'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '15672410112'
Error 'Scsi error - MEDIUM ERROR:ID CRC OR ECC ERROR' occurred while reading '/BDMV/STREAM/00005.m2ts' at offset '15747643392'
Failed to save title 2 to file /Users/mrtuneup2/Movies/Gangster_Squad/Gangster_Squad_t02.mkv
0 titles saved, 1 failed
crowfax
Re: Problems Ripping Gangster Squad . . .
Post by crowfax » Sun May 12, 2013 11:04 pm
Your drive can't read the disc. This is not a copy protection issue. Your disc is bad or the drive is failing.
Try using the "backup" feature and it'll tell you which files on the disc it is unable to read, but what you really need to do is swap the disc for a new one.
