Backed up 3D bluray folder to 3DMKV
laptopdoc
#1 Post by laptopdoc » Sat May 11, 2013 5:47 pm
I am new and just started using makemkv. I have on my hard drive the backup of the movie hugo in 3d. (I do not have the original disc). how do i convert this into 3DMKV. should i just choose the index file in the bdmv folder and press make mkv or is there a different way to do it. Sorry if this question has been posted already.
twa000
Re: Backed up 3D bluray folder to 3DMKV
#2 Post by twa000 » Sun May 12, 2013 7:21 am
laptopdoc wrote:Hi,
Open Index, then when you see the streams, right click on the stream you want to convert and make sure you then at least tick the MVC box.
laptopdoc
#3 Post by laptopdoc » Sun May 12, 2013 4:54 pm
thank you so much i will try that right now.
