Fatal Error Version 1.81
critter
Post by critter »
My has fatal error when trying to open program, went back to version 1.80 and works just fine, something has changed and it is not for the good, hope this is solved soon
hogger129
Re: Fatal Error Version 1.81
Post by hogger129 »
I am having issues also. On a couple of my Blu Ray discs, MakeMKV will not save. The first couple times, it would stop about halfway through, just error out. Next few times I got it to get to the end, but it just sat there for about 2 hrs. Next time, it gets to the end, but cannot save the title to an .mkv.
I have always been able to rip directly from the disc, but I have also tried ripping the BD to an ISO using AnyDVD HD, and got the same result.
BD is not scratched, not new either.
I'm trying to convert the TrueHD and DTS-MA tracks to FLAC (and have the decoder for DTS-MA), but even when I don't choose to convert them to FLAC, I get the same results. Program errors out, hangs or can't save.
I experienced this in 1.8.0 as well.
Tried using previous versions, getting the same results.
I don't think it's my Blu Ray drive because I was importing CD's with it all day, and ripped a BD yesterday and it worked fine.
hogger129
Post by hogger129 »
Let it run, and same thing. It gets to the very end, then fails to save.
I attached my log file.
MakeMKV_log.zip
(375 Bytes) Downloaded 373 times
