Can't rip Disney Mickey Mouse Clubhouse
Medvidek
Post by Medvidek »
I've been trying to rip my new Mickey Mouse Clubhouse DVD using makemkv 1.8.1 and getting navigation error. Other Mickey Mouse DVD suffer the same issue.
I tried with AnyDVD but no success. Do you have any suggestion for me? Thank You in advance. Here's the log:
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
CellTrim algorithm failed since title has only 3 chapters
Title #1 (0:23:06) was skipped due to navigation error
Title #2 (0:23:06) was skipped due to navigation error
Title #3 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
VIDEO_TS.zip
(859 Bytes) Downloaded 571 times
Tolken
Re: Can't rip Disney Mickey Mouse Clubhouse
Post by Tolken »
MMC dvds were weird on me too. I did find a workaround for the disk I had.
Try ripping it into an ISO first (remember to have it decrypted) then have MakeMKV process it.
Medvidek
Post by Medvidek »
Thanks for the tip. I ripped Mickey Moused Clubhouse DVD to ISO using AnyDVD and then tried makemkv but didn't succeed. Still encountering "navigation error". The only workaround is to use IFO Edit program to fix IFO.... but that's too much work for me. It would be great if makemkv itself can pass through Disney DVD protection itself. I'll try makemkv later again and hope this problem gets on developer's stack.
