I am trying to backup Monsters Inc. 3D to MKV. The disk will read and the MVC stream is being seen. The problem occurs when I start the actual copy. It starts off and then fails quite quickly with debug codes and the following error:
Exception: Error while reading input!
It doesn't matter what options I have ticked. Except it takes longer to fail if the 3D option is not ticked.
I have included the error report log file and the folder of files from the bluray in the attached zip. Please feel free to contact me if you need more information.
Good luck on working this one out. Thanks.
Monsters Inc. 3D will not convert to MKV. Error....
- Monsters Inc. 3D - Error Report.zip
- Contains small files from bluray disk and the error log from MakeMKV.
- (394.21 KiB) Downloaded 1352 times
- Contact:
Re: Monsters Inc. 3D will not convert to MKV. Error....
The error is due to corrupted MVC data. Please submit a testdump per /onlinehelp/testdump.html .
Ok here is a link to the new test dump file:
https://mega.co.nz/#!dU8HSaCI!esI_cgN6m ... fOmWaVqLQQ
Good luck on working it all out. Let me know if you need additional information.
Cheers.
Cheers.
