Monsters Inc. 3D will not convert to MKV. Error....
Everything related to Blu-ray 3D and 3D MKV files
ant75
Post by ant75 »
I am trying to backup Monsters Inc. 3D to MKV. The disk will read and the MVC stream is being seen. The problem occurs when I start the actual copy. It starts off and then fails quite quickly with debug codes and the following error:
Exception: Error while reading input!
It doesn't matter what options I have ticked. Except it takes longer to fail if the 3D option is not ticked.
I have included the error report log file and the folder of files from the bluray in the attached zip. Please feel free to contact me if you need more information.
Good luck on working this one out. Thanks.
Monsters Inc. 3D - Error Report.zip
Contains small files from bluray disk and the error log from MakeMKV.
(394.21 KiB) Downloaded 1140 times
Re: Monsters Inc. 3D will not convert to MKV. Error....
Post by mike admin »
The error is due to corrupted MVC data. Please submit a testdump per /onlinehelp/testdump.html .
ant75
Post by ant75 »
Ok here is a link to the new test dump file:
https://mega.co.nz/#!dU8HSaCI!esI_cgN6m ... fOmWaVqLQQ
Good luck on working it all out. Let me know if you need additional information.
Cheers.
