No Audio on MakeMKV raw files
JDErickso
#1 Post by JDErickso » Fri Apr 26, 2013 9:10 pm
When I rip a BR with Makemkv and then try to play it through DLNA through my Onkyo system there is no sound.
If I used Handbrake to reduce the size then the audio works fine.
Anybody have this problem?
Re: No Audio on MakeMKV raw files
#2 Post by Woodstock » Sat Apr 27, 2013 2:46 am
Most likely, the Onkyo doesn't support the audio format you have selected. Running it through handbrake converts the default track to something the Onkyo does understand.
