what is up with Eagle Eye
Hello there,
I'm having trouble with my Blu Ray "Eagle Eye". If I'm trying to load the disc I'm getting Medium Errors all over the place. So I kept PowerDVD and makemkv running and inserted the Blu Ray. Suddenly the Disc gets read without any errors. I check the main title, strip some subtitles and audio tracks and start ripping. 11GB into the Movie I get:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occured while reading '/BDMV/STREAM/00000.m2ts' at offset '15281405952'
and the rip is terminated. Does this sound like BD+ or am I forgetting something? Btw. AnyDVD HD fails at the identical position. What do you say, is it likely that the disc is damaged?
Greetings, rws
Greetings, rws
Re: what is up with Eagle Eye
Nothing to do with BD+ (MakeMKV would let you know during its initial pass if the disc contained BD+ protection - and, anyway, MakeMKV can process it).Does this sound like BD+ or am I forgetting something? Btw. AnyDVD HD fails at the identical position. What do you say, is it likely that the disc is damaged?
If two programs are stopping at the same point, it's quite likely that the disc is either physically damaged or dirty...
I have to agree with damaged. I had no problem ripping Eagle Eye.
Hi!
I have not a problem with this one, ripped fine 4 me.
I looked at this disc and discovered BD+ wasn't even on it. It only has AACS.setarip_old wrote:Nothing to do with BD+ (MakeMKV would let you know during its initial pass if the disc contained BD+ protection - and, anyway, MakeMKV can process it).Does this sound like BD+ or am I forgetting something? Btw. AnyDVD HD fails at the identical position. What do you say, is it likely that the disc is damaged?
Hello there,
first of all, thanks for the replies and sorry for my delay. I did two things, I changed the disc and I bought another Blu Ray Drive. I tested the new Disc in the old LiteOn iHOS104-32 and still no dice. I installed the new LG CH08LS10 with Firmware 1.0 and tried my luck. The disc gets recognized (hail LG), but again, I got errors. So I updated the Firmware to 2.0 but still I get
This happens while the Disc gets loaded, before actually extracting the tracks and also during the extraction of the tracks which ultimately results in a failed rip.
I swapped drive and disc (it's a rented version), any ideas? It's the only disc so far I had problems with.
greetings, rws
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occured while reading 'BD-ROM HL-DT-ST BDDVDRW CH08LS10 2.00' at offset '1844574208'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occured while reading 'udf:/BDMV/STREAM/00000.m2ts' at offset '3727773696'
File 00000.mpls was added as title #0
Title #00002.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00013.m2ts was added as title #1
File 00014.m2ts was added as title #2
File 00015.m2ts was added as title #3
File 00016.m2ts was added as title #4
File 00017.m2ts was added as title #5
File 00018.m2ts was added as title #6
File 00020.m2ts was added as title #7
Title #00022.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00063.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00064.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00068.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 2 titles into directory /home/somedude/Eagle_Eye_video
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occured while reading '/BDMV/STREAM/00000.m2ts' at offset '92469248'
Failed to save title 0 to file /home/rws/Videos/untouched/Eagle_Eye_video/title00.mkv
1 titles saved, 1 failed
greetings, rws
OOPS!I swapped drive and disc (it's a rented version), any ideas?
BIG OOPS! hahahasetarip_old wrote:OOPS!I swapped drive and disc (it's a rented version), any ideas?
- Contact:
As setarip_old have mentioned, this forum is not for discussing any illegal activity including ripping and storing rental discs. Please retain from useless posts in future.GoColts wrote:BIG OOPS! hahaha
Good evening,
I'm sorry, I'll have to clarify things. I OWN Eagle Eye and lots of other discs (250+ DvDs, around 50 BluRays). But as I set up a linux media htpc system I cannot really use PowerDVD, can I? To make sure that I do not have a faulty disc, I additionally rented the disc and tried that one. So afterall I paid TWICE for the disc and still can't play it. Sorry that I posted that in a rather confusing manner. I just wanted to ask if there might be a difference between the rental and the consumer version additionally to the drive obviously not being able to handle the disc.
Regards, rws
Regards, rws
@ridewithstyle
Instead of "paying twice", why don't/didn't you simply return your purchased BluRay to the place of purchase in exchange for a new replacement?
Because I already did that, hence the rented copy and the new drive.
